Mercedes W13
zibby43
zibby43
613
Re: Mercedes W13
Sorry if already posted. via Stefan Baldauf of AMuS
Mercedes, Ferrari and Alpha Tauri have even pulled the nose down to above the lowest element. These three teams therefore have the longest noses in the field, but their shapes differ significantly. For example, the rounded and elegant tip of the Silver Arrow protrudes particularly low down.
"The Mercedes solution with the deep nose generates more downforce at the front. They need it for balance because they obviously have a lot of it in the rear," an engineer from the competition tells us. A short nose, on the other hand, allows more air to flow under the car to the rear.
- AMuS
SuperCNJ
SuperCNJ
Re: Mercedes W13
Just out of interest,assuming the overweight claims are to be believed, if a team is double digits overweight, how would they go about reducing it without compromising performance too much? I guess they could use more exotic materials that weigh less but have similar properties which wouldn't need a redesign. Are there any other areas or ways they could lower the weights? 10+ kg is pretty significant when everything is already pretty lean and measured to the gram.
Big Tea
99
Re: Mercedes W13
SuperCNJ wrote: ↑
07 Mar 2022, 18:53
In extreme cases it could mean reducing radiator size and capacity, 1ltr = 1 KG (ish) reducing depth of wings etc, but I would suggest removing or incorporating ancillaries.
It will be difficult to remove material if the crash teats have been passed.
Re: Mercedes W13
Obviously I don't work in an F1 team, but I believe the overweight is likely caused by simpler, faster to machine parts that you would use for testing purposes. Imagine spending 15% more machining time to make a part lighter when the team urgently needs to get the car assembled and running to test other more complex systems. They will not waste time with this so inevitably, the teams will have many heavier than race-spec parts on the car in winter testing. The additional weight of prototype non-critical parts, like say the bracket that holds the pedals, or the strut that holds the bib, or some bracket for electronics boxes or the like is not relevant to their testing programme. That extra 10kg won't change their findings. So coming up to the second test, and the first race I suspect they will produce fully machined out parts and lighter body-work.
β˜„οΈ Myth of the five suns. β˜„οΈ
β˜€οΈβ˜€οΈβ˜€οΈβ˜€οΈβ˜€οΈ
LxVxFxHxN
mclaren_mircea
mclaren_mircea
Re: Mercedes W13
https://it.motorsport.com/f1/news/f1-il ... o/8784054/
yes!!! only 3 Kg permitted. So 798 kg the weight limit. Sauber and Mclaren are on it, Mercedes only 1 kg over, Ferrari 3 kg overall. That is the point. The teams knew they had to make compromises on weight versus performance from the begining. The teams that have the car overweight if they dont lose performance on coming to the limit than at least should waste some resources by coming down to 798 kg.
Stu
Re: Mercedes W13
mclaren_mircea wrote: ↑
07 Mar 2022, 19:21
I still think that shows a lack of backbone by the FIA. The minimum weight should be seen as a target, if too easily achievable it becomes a poor target. Later this year, when some development has taken place and the cars get below the weight limit, will the limit be reduced to the original?
A very poor show!!
OO7
OO7
171
Re: Mercedes W13
Stu wrote: ↑
07 Mar 2022, 19:29
07 Mar 2022, 19:21
A very poor show!!
Completely agree.
mantikos
mantikos
Re: Mercedes W13
While I am no fan of increasing the weight, y'all are missing the fact that the wheels and tires came in 1 kg over the model, and the rim aero covers were never included in the model weight that's 2/3 of the 3 kgs right there. The FIA screwed up.
dans79
267
Re: Mercedes W13
PlatinumZealot wrote: ↑
07 Mar 2022, 19:05
A good chance exists that this is part of it. I'd add that depending on the part,and its geometry, 15% could be very low. I've seen parts where the finishing passes with small endmills is 90-95% of the total operation time.
Another possibility is that the teams are using lower modulus CF (aka cheaper) for testing, but this means they need more of it.
197 104 103 7
Re: Mercedes W13
Stu wrote: ↑
07 Mar 2022, 19:29
07 Mar 2022, 19:21
A very poor show!!
Agreed. The teams all know the minimum weight limit and they make design choices for their car. If they choose a route that keeps them above that minimum weight limit, then that's their problem. Other teams have got down to the limit (or close to it) and they should benefit from having done that.
I bet if it was Alfa and Haas that were well over and Red Bull et al were achieving the limit, the limit wouldn't be changed. It's just the usual baking in of help to the big teams at the expense of the small ones.
mzso
mzso
Re: Mercedes W13
GrizzleBoy wrote: ↑
06 Mar 2022, 20:26
mzso wrote: ↑
06 Mar 2022, 18:43
shamyakovic wrote: ↑
04 Mar 2022, 10:15
Sacry isn't it... I have never seen such photos of new car especially with new regulations
Isn't it mere CGI? It feels like that to me.
Why spend the many many man hours it takes to create CGI when you can just put a camera in front of the car that already exists?
Ask the teams, they always do it.
dans79
267
Re: Mercedes W13
mzso wrote: ↑
07 Mar 2022, 20:34
GrizzleBoy wrote: ↑
06 Mar 2022, 20:26
mzso wrote: ↑
06 Mar 2022, 18:43
If you have a cad model, it doesn't take much time either, as a lot of packages have very advanced rendering functionality built in.
197 104 103 7
f1316
f1316
79
Re: Mercedes W13
mantikos wrote: ↑
07 Mar 2022, 19:52
This. Increasing by the amount that was (according to this article anyway) a result of the weights of components provided to the teams being incorrect seems pretty logical. Any more than that, I agree, is the team’s’ responsibility.
hollus
Re: Mercedes W13
Car thread, W13. Thanks.
Rivals, not enemies.
Phlumbert
Phlumbert
Re: Mercedes W13
https://www.corriere.it/sport/formula-1 ... 0451.shtml
Not sure about this source, seems a little far fetched.
