Mercedes W15
mkay
mkay
16
Re: Mercedes W15
Doesn't look like Hamilton is running the new front wing in FP1?
Re: Mercedes W15
mkay wrote:
24 May 2024, 13:46
I believe he has the first version of FW.
Russell v Hamilton
zibby43
zibby43
Re: Mercedes W15
https://x.com/albertfabrega/status/1793 ... w2eCbwUjFA
Someone feel free to embed the images. I used to know how. I know the various tools to implement but I believe I also have to parse part of the hyperlink. Just can’t recall which portion. Apologies.
Mattchu
58
Re: Mercedes W15
Courtesy Albert Fabrega via zibby43
zibby43
zibby43
Re: Mercedes W15
Thank you!
In the overhead frontal view, you’ll notice a new wake control flick/element upper left of frame on the new spec.
Near where topmost flap meets the end plate.
Mattchu
58
Re: Mercedes W15
zibby43 wrote:
24 May 2024, 15:19
Thank you!
This little beauty...
mkay
mkay
16
Re: Mercedes W15
I imagine Russell and Hamilton split front wings to test the new spec. Doesn't look like an improvement at this track, as Hamilton was clearly the faster driver of the two.
zibby43
zibby43
Re: Mercedes W15
mkay wrote:
24 May 2024, 15:34
There was an explanation provided for that by Ted Kravitz.
“"Did it work? Given Russell was on the new and Lewis was on the old, what does it say as to why Lewis was quicker than George?
"The team say it's not down to the front wing. Russell had a big axel and front brake vibration which limited his progress throughout the session.
That made a true read on the efficiently of the front wing pretty tricky.
"They do believe the new front wing is doing what it should be, even though the benefit of downforce here is a little bit decreased compared to some other circuits we go to.”
cplchanb
cplchanb
Re: Mercedes W15
zibby43 wrote:
24 May 2024, 15:41
mkay wrote:
24 May 2024, 15:34
so are they abandoning their novel legality strip concept if theyre intending to use this wing going forward? maybe the gains with the former was not enough to outweigh the imbalances.
Luscion
Luscion
117
Re: Mercedes W15
Monaco at the top, Imola below
zibby43
zibby43
Re: Mercedes W15
cplchanb wrote:
24 May 2024, 15:48
zibby43 wrote:
24 May 2024, 15:41
mkay wrote:
24 May 2024, 15:34
I think that’s likely the case, particularly if we see both cars adopt moving forward. The scope of the changes implemented signal a new design direction as opposed to circuit-specific tweaks.
Formula 1 fan
Formula 1 fan
-2
Re: Mercedes W15
Were both cars driven with all the new upgrades in first practice?
Luscion
Luscion
117
Re: Mercedes W15
Formula 1 fan wrote:
24 May 2024, 16:55
Lewis used the old front wing, Russell used the new one
Formula 1 fan
Formula 1 fan
-2
Re: Mercedes W15
Luscion wrote:
24 May 2024, 16:55
24 May 2024, 16:55
Okay, why didn't both cars use new front wings?
Luscion
Luscion
117
Re: Mercedes W15
24 May 2024, 16:57
Luscion wrote:
24 May 2024, 16:55
24 May 2024, 16:55
Most likely to compare the new one to the old, get an idea of if it's working as expected and the difference between the two, if any
