Formula E
Andres125sx
Re: Formula E
J.A.W. wrote:Currently it seems that FE lack the energy required to overcome gross cornering assistance aids such as wide super-sticky tyres
Sorry but this is BS
super sticky tires will provide some added drag, but the difference is so small you can´t seriously say they don´t have enough energy to use them
They don´t use them because they want FE to be road relevant, as simple as this, they explained this point more than once. And this Michelin tires are light years ahead of F1 tires when talking about road relevance
And I´m really glad they took this aproach, because super sticky tires mean super dirty tracks out of the line due to the marbles, what makes overtaking a lot more difficult and the category a lot more boring
J.A.W. wrote: & massively draggy aero-downforce devices,
Same as F3, wich is the category they were trying to compare.
F3
FE
J.A.W. wrote: ( & perhaps, the power to run active aero?)..
Sorry but more BS
Active aero would be just the opposite, they could use flat wings at the straights to avoid the act as airbrakes, and use high downforce (and drag) configs at the corners to improve cornering speed... and braking too.
So they could be faster both at the straights and at the corners no matter how much power the motor provide
J.A.W. wrote:Although, evidently, the speed they do make - does not warrant too much - in the way of this stuff, anyhow..
How much downforce do the monkey seat provide on a F1? Not much really. But they use it anyway.... Weird people this F1 engineers... :mrgreen:
mzso
mzso
68
Re: Formula E
hollus wrote:@mzso: Only with ground effect you get the downforce you get in the part of the car where you get it, and that's it. If it doesn't suit the circuit, tough luck. Plus underfloor downforce can suddenly disappear, say going over one of those monster kerbs.
Downforce from wings, while being less efficient, is more constant, and it is tunable. You can transfer downforce to the front or the back of the car, or increase it or reduce it overall, just by changing the angles of attack. This way you can suit the car to the different layouts, ambient conditions, etc. It it rains, you crank both wings up. That's what I meant with balance.
If you take a closer look, you'll see that I wasn't promoting actual ground effect, in which case the issues you mentioned would be present. But if you don't have the sideskirt/sideplates, etc you won't get these issues.
The Byren/Head proposal provided an incredibly simple and fool proof solution: making the sides of the car further from the ground than the middle. Thais way they can't cheat with the suspension.
I'm not sure about tunability without wings, but I think it should be possible if you let the end/"tail" of the car to be adjusted, maybe you could do it to the leading edge. Or maybe even allow an opening somewhere half way.
Anyway, in my opinion an EV racer should be primarily efficient, even if it's at the cost tunability.
Even F1 vent into a more efficient direction, though it's mostly just PR. The aero is still a giant wind catcher, which eats up most of the energy.
Re: Formula E
If you take a closer look, you'll see that I wasn't promoting actual ground effect, in which case the issues you mentioned would be present. But if you don't have the sideskirt/sideplates, etc you won't get these issues..
Underbodies are sensitive to changes in pressure with or without skirts. The gdownforce from the floor changes when ride height/rake/whatever position changes.
(sudden) loss of downforce is an issue with aero devices close to the ground, with or without skirts.
Re: Formula E
J.A.W. wrote:If FE lack the energy to provide full power for a race, how will it accommodate the power draw
to enable a modern powered active aero downforce system?
I don't think a simple electrical switch will consume much power. Plus, the power saved by drag reduction will almost certainly outweigh power consumed by active aero.
J.A.W.
J.A.W.
109
Re: Formula E
W-123 - to what "simple electrical switch" do you refer?
By "active aero" I mean a properly integrated ECU/servo-operated system of variable planes/flaps/slats & etc..
Thinking say.. A2A guided missile..
henry
324
Re: Formula E
J.A.W. wrote:W-123 - to what "simple electrical switch" do you refer?
Try thinking DRS.
mzso
mzso
68
Re: Formula E
wesley123 wrote: Underbodies are sensitive to changes in pressure with or without skirts. The gdownforce from the floor changes when ride height/rake/whatever position changes.
You're still thinking of ground effect, which only happens if you have sideskirts or if you have a lot of flat surface very-close the ground which was the case in the early nineties.
That's why I said wing-car because you can take measures against actual ground effect and just have the shape of the body provide downforce.
Andres125sx
Re: Formula E
What´s the problem with the skirts?
We´re on 2015, not 90´s. Active suspensions would solve that problem, plus some sort of active skirts could be implemented to accomodate when the car run over a kerb. Even pasive could solve the problem.
But even if that´s not possible, maybe it could be the solution to stop climbing over the kerbs more and more each season.... If you go too far up the kerb you loose ground effect so it´s up to you to decide the risk you assume, same as going close to a wall at the exit of a corner.
Ground effect could be perfectly safe today
mzso
mzso
68
Re: Formula E
Andres125sx wrote:What´s the problem with the skirts?
Skirts are unreliable, there's no way to fix that.
Andres125sx wrote: Ground effect could be perfectly safe today
Nope. How do you imagine?
Any sort of unevenness or disruption could cause most of the downforce to go disappear. So it's inherently more dangerous.
On the other hand without skirts you dont have the sort of low pressure that can suddenly disappear.
Re: Formula E
To simply operate such things doesn't require much power, certainly not the amount gained. Of course, you could over-complicate it, but is that really necessary? In the end it comes to a simple thing; less drag on the straights, more downforce in the corners.
mzso wrote: You're still thinking of ground effect, which only happens if you have sideskirts or if you have a lot of flat surface very-close the ground which was the case in the early nineties.
Current cars with the step in their floors still suffer the same problem, just to a lesser extent because the gap is larger.
Andres125sx wrote:We´re on 2015, not 90´s. Active suspensions would solve that problem,
To a certain extent, yes.
Except the gap between the ground changes and you won't be able to maintain the perfect seal necessary to maintain the necessary downforce.
Except suddenly losing large amounts of downforce is quite dangerous.
No. It's still as dangerous as it was when people first found out about it. The laws of physics don't change.
Andres125sx
Re: Formula E
Law of physics don´t change, but technology evolve, and active skirts are plausible today. I´m thinking about a sensor taking distance and adjusting skirts height to match it, or even a simple spring moving down the skirt until it seals the gap...
But I´ll repeat, even if they´re not possible, just with active suspensions ground effect could be used. If they go over a kerb it will dissapear.... and the car will slide... What´s the problem?
Same as if they go over grass, they will loose most of the grip and will slide...
And there´s even more extreme examples..... what if they go too wide here?
What I mean is even if active skirts are not used, they could cope with a car they know can´t go over kerbs. If they can get close to a wall with milimeters margin, they could avoid going over kerbs with a ground effect car.
Afte all if they fail and go over the kerb it still will be less dangerous than if they fail and hit a wall as they´re doing constantly on Monaco, Montreal, Singapour, Abu Dhabi....
Re: Formula E
Andres125sx wrote:Law of physics don´t change, but technology evolve, and active skirts are plausible today. I´m thinking about a sensor taking distance and adjusting skirts height to match it, or even a simple spring moving down the skirt until it seals the gap...
Still changes the height between the body and the ground, and thus, downforce.
The problem is that their grip is suddenly gone. These cars require downforce to maintain their cornering speeds. Take that away and their grip is gone. Losing that grip when going through a corner at a solid pace doesn't sound very safe to me.
What about a sudden increase in yaw, or other incidents?
Except they can correct, compensate and expect. not so much when downforce is suddenly gone in a unpredictable fashion.
flynfrog
Re: Formula E
Id be willing to bet there would be more to be gained by taking the wings off the formula E car and putting real slicks on them. Road relevance is crap tires and single seat open wheel cars with wings i guess. They would probably use less energy in this configuration less drag more momentum carried through the corner.
mrluke
mrluke
Re: Formula E
You could use a fan to have consistent down force..
Re: Formula E
mrluke wrote:You could use a fan to have consistent down force..
Which brings the issue of debris being thrown up, plus packaging the whole thing.
