One doubt: a 4mm fillet on the bottom edges of the floor board breaches the flat floor rule?
I think it is OK (K 3.3-floor )rjsa wrote:The Idadox VR1 is rolling out soon.
http://i.cubeupload.com/IDqWyS.jpg
Very good point.JJR wrote:Hi,
As we are going to LeMans 4 long straigts are important .
I would like to ask how much power does have MVRC car.
I know it is 540hp+144hp (ERS) =684hp. But those 144hp from ERS are avaliable for all time or just for acceleration time? (lets say for certain time for example 40 seconds for hole circuit)
I m thinking about to do not run out of engine revs at those long straights.
For example Variante has CdA=0,724 and with 684hp his teoretical max speed is around 230mph and mvrc car is geared to 215mph so he does not use his full potential of his low drag design
Thanks
Unbroken means holes, not what you are describingrjsa wrote:It says an unbroken surface. I have 4mm fillets on both the leading and trailing edges of the regulation floor guide.
If you PM or email me an image I can give you a definitive yes or no.rjsa wrote:One doubt: a 4mm fillet on the bottom edges of the floor board breaches the flat floor rule?
That's correct.rjsa wrote:About the rear wing guide: It's just a size guide and it can sit anywhere within the rear wing volume, right?
Yes; Good question!CAEdevice wrote:Very good point.JJR wrote:Hi,
Thanks
Machin could help us, I miss his presence on the forum.
machin wrote: The issue of running out of revs at Le Mans is a good point: I will check this and if need be I will simply add an additional gear to the car model so that the performance below 215mph is unaffected.
Code: Select all
solid
facet normal -1.000000 0.000000 0.000000
outer loop
vertex 2.166200 -0.375000 0.397000
vertex 2.166200 -0.375000 0.406700
vertex 2.166200 -0.365100 0.406700
endloop
endfacet
outer loop
vertex 2.166200 -0.365100 0.397000
endloop
endfacet
outer loop
vertex 2.166200 -0.375000 0.387200
endloop
endfacet
