Red Bull RB20
vorticism
vorticism
449
Re: Red Bull RB20
https://x.com/AlbertFabrega/status/1763150258895237628
Fabrega
Need to update the media link code to include the URL for x.com
๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ
Lefty8
Lefty8
Re: Red Bull RB20
PlatinumZealot wrote: โ†‘
29 Feb 2024, 03:48
RedBull's cooling design philosophy is bring all the coolers as much forward as possible so that the hot air blowing off of them gets time to straighten up before exiting the engine cover. Should be cleaner air flow to the rear wings.
huh???!!! :wtf:
Re: Red Bull RB20
This is what James Allison is implicity refering to. The CoG and weight compromises of brining the coolers forward. They even abandoned their big "centre-line cooler" they had for years.
shady
shady
Re: Red Bull RB20
They are using the heat from the exchangers and blowing another surface. Most likely a result of the unlimited WTTesting for cooling. But that hot air is being sent somewhere, and its not for shiggles. I would love to see the backside of that ductwork
venkyhere
43
Re: Red Bull RB20
vorticism wrote: โ†‘
29 Feb 2024, 18:58
Fabrega
https://pbs.twimg.com/media/GHf3zsqWoAA ... ame=medium
What are those two curved fairings rearwards of the body, just after the side vents and just below the elephant-trunks ?
Venturiation
Venturiation
103
Re: Red Bull RB20
What is the red cover on the rear floor
Re: Red Bull RB20
Venturiation wrote: โ†‘
01 Mar 2024, 17:40
Rb covers the vertical inlet, but Ferrari does not.
Beware of T-Rex
Venturiation
Venturiation
103
Re: Red Bull RB20
AR3-GP wrote: โ†‘
01 Mar 2024, 17:48
01 Mar 2024, 17:40
I'm talking about the rear floor not the 2 inlets
Re: Red Bull RB20
01 Mar 2024, 17:51
AR3-GP wrote: โ†‘
01 Mar 2024, 17:48
01 Mar 2024, 17:40
Sorry, I didn't see your question. I was just making a comment on the images in the post.
To the question, it's probably the tire temperature sensor that is covered.
Beware of T-Rex
Re: Red Bull RB20
The waterslide dips almost early and aggressively like the Williams.
Owen.C93
Owen.C93
191
Re: Red Bull RB20
01 Mar 2024, 17:40
https://pbs.twimg.com/media/GHkKS_hXcAA ... name=large
In other pictures itโ€™s a really small opening. Probably tyre temp sensor.
https://ibb.co/LJLHYRw
matteosc
matteosc
32
Re: Red Bull RB20
AR3-GP wrote: โ†‘
01 Mar 2024, 17:48
01 Mar 2024, 17:40
Ferrari's are not for cooling (presumably), but only for the S-duct. This would confirm that Red Bull's vertical inlets are for cooling purposes.
Re: Red Bull RB20
matteosc wrote: โ†‘
02 Mar 2024, 16:23
AR3-GP wrote: โ†‘
01 Mar 2024, 17:48
01 Mar 2024, 17:40
There's a compressor inlet theory floating around as well. I agree that it is only similar in appearance.
Beware of T-Rex
vorticism
vorticism
449
Re: Red Bull RB20
AR3-GP wrote: โ†‘
02 Mar 2024, 16:50
matteosc wrote: โ†‘
02 Mar 2024, 16:23
AR3-GP wrote: โ†‘
01 Mar 2024, 17:48
Hypothesis 8) and I'm still waiting to see some confirming details. We're at race day today so it won't be until the next venue that new photos will be available.
24 Feb 2024, 22:41
The thin times between testing and first race where I analyze 1/20th of a low resolution image...'
First view of how they plug the inlets in the garage. Foam insert with cooling hoses into the main inlet, typical. The vertical slot has similar foam jammed into it as well, looks like a sheet inserted edgewise. No hose visible connected to it. The red strip at left is livery, ignore it.
This might rule out that it's an aero duct (S-duct or similar) because: why would you block it off in the garage?
If there's no hose connected to that plug in the vertical slot, then:
-likely not for dedicated cooling flow
-could indicate connection to the main inlet plenum to prevent cool air from the hoses leaking out
-engine intakes get plugged for shipment & garage... although I'm having my doubts about this supposition. The roll hoop looks too large relative to the radiator that's behind it i.e. the roll hoop looking like it's not 100% cooling inlet
https://i.postimg.cc/xjBYxc93/rb20-inlet-plugs.jpg
RB19 shipping plugs:
https://external-content.duckduckgo.com ... ipo=images
lio007
327
Re: Red Bull RB20
GP mentioned a few times "tools" on team radio. Something like "you can use the tools if you need".
Any idea about this tools?
