2026 Drama: Alleged engine loophole
WardenOfTheNorth
Re: 2026 Drama: Alleged engine loophole
upsidedowntoast wrote:
17 Feb 2026, 02:24
This is very unlikely given the amount of chatter and smoke present, but I would *love* the truth to be that there was no special secret compression ratio trick, but something else -- and in fact Mercedes came to the same conclusion as Red Bull awhile back which is that "yeah we tried and this doesn't work". And the fear around the test change isn't that it will render their engines illegal, but that it will reveal their engines weren't special at all, drawing attention to something else that they're doing.
https://pbs.twimg.com/media/Fm1CIcZaYAMv96e.jpg
Or if it turned out that Red Bull were in fact doing something but didn't think it would show up in a revised test.
I do not think that is the case, just to be clear, but I would find it funny.
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
Stu
17 Feb 2026, 02:24
^^THIS^^
Case closed…..
michl420
michl420
Hoffman900 wrote:
16 Feb 2026, 22:18
This chamber idea doesn’t make any engineering sense.
I can guarantee 230bar+ of cylinder pressure is going to find its way through a 0.3mm gap.
Yes, but would it 2 times in 0,012 seconds (1 compression and work stroke at 10000 upm) in a meaningful amount?
vorticism
vorticism
449
If it is a "sub-chamber linked by small hole(s)" then it's a brilliant interpretation of the rules. Amuses me. Meets the wording of the rules while creating new freedoms. Potentially satisfies the geometric compression ratio at all times and temperatures (yes) while providing more advantageous pressure seen by the fuel.
A big question is what is the test and what does it entail. If it can pass a CAD inspection but not a working test then it's not clever, too ban-able. If it can pass the test and meet the unpublished definitions of "cylinder" and "geometric compression ratio" then it is clever. Furthermore if it has a plausible function (f.e. as a shock absorber, wymc a hammer arrestor protecting against catastrophic pressure spikes) of some sort, it would defend its existence. Think also in terms of acoustics, shock wave dynamics, latency of pressure distributions, trade-offs of a lowered a:f ratio vs. raised charge pressure, etc. A void even with a not-so-small, test-passable connection will exhibit filling latency which would provide the fueled air with higher pressure while the geometric compression ratio remains unchanged at 16:1, at all times, at all temperatures.
The TJI chambers and their small holes were either already tested before--or ignored, depending on the test parameters. Is an assumption that the previous 18:1 was demanded but never tested? If TJI chambers can pass this test, what is the limit for orifice sizes in terms of passing the test.
If a sub-chamber is formed in part by the permitted spark plug sleeve, it would be relatively easy to implement all of this. Holes in the sleeve linked to an annular void that encompasses it, formed against the head. More speculatively (i.e. too easily ban-able): Differential thermal expansion of a steel sleeve and an aluminium head could result in eclipsing of the holes--hence the rule change to a hot test? But this is too on the nose. Too obvious of an intent. There needs to be a true function.
There are multiple concepts which can satisfy the tenets of the rumors. One or more of them could be correct. Or none. Although it seems like a lot of chatter for it to be none.
dialtone
dialtone
139
FIA already said a chamber would be illegal afaik
gearboxtrouble
gearboxtrouble
There is no scenario where a device that only exists to allow an engine to pass the test will ever be judged legal. Its a cheat that allows an illegal engine to pass and race and there are precedents that have deemed components like this illegal in the past.
motobaleno
gearboxtrouble wrote:
17 Feb 2026, 17:28
there is a specific word for this: it would be a defeat device
Lasssept
135
WardenOfTheNorth
Lasssept wrote:
18 Feb 2026, 00:07
Just reinforces what many of us have asked: how can they accurately measure the geometric dimensions at operating temperature?
Just change the wording and include "at all times" or have teams sign an affidavit. Doing this circus with the testing is just inviting teams to work around them. Mercedes knows their compression ratio is above. Toto Wolff admitted it already so any test that they are rumored to have passed simply means that the test is inadequate.
Mercedes is not here to make a point that their engine is compliant. They just want it to pass the test even though they admitted that it is designed to operate outside of the limit. Saying that they passed a test just means they have made a mockery of your system.
Beware of T-Rex
Hoffman900
Hoffman900
243
Hysterical because even NASCAR is running near 140* C coolant temp (average) and and 140* C oil (sump) with localized temps in excess of 180* C. All for aero reasons (less cooling, better aero). F1 is about the same or a bit more. Piston crown temperatures will be in excess of 300* C, the exhaust valve and TJI unit will be higher.
That said, for the two dozen time, 1-1.5mm of clearance vanishes in most engines. This is just normal stuff.
The chamber idea is beyond silly.
motobaleno
WardenOfTheNorth wrote:
18 Feb 2026, 00:24
That's rather puzzling. The article strongly confirm the 2nd chamber hypothesis. But if true, that automatically vanish any hot measurement...the geometric static cr of that thing will always be 16 no matter the temperature...only running the dynamic cr will be higher...some nonsense going on here
motobaleno
Hoffman900 wrote:
18 Feb 2026, 00:37
You mean because It would be mechanically unfeasible/problematic?
upsidedowntoast
upsidedowntoast
motobaleno wrote:
18 Feb 2026, 01:06
18 Feb 2026, 00:24
I think that's a joke screenshot, as no such article is appearing for me on the main motorsport.com website.
Lasssept
135
18 Feb 2026, 01:49
https://it.motorsport.com/f1/news/f1-la ... /10798436/
