[MVRC] Mantium Virtual Racecar Challenge 2017
variante
139
Re: [MVRC] Mantium Virtual Racecar Challenge 2017
Awesome, Gary and Matteo! Looking forward to seeing the car running on track!
Great news, Andre'. Now I need to win the last race to have my car featured on the magazine :D
LVDH
52
variante wrote:
17 Nov 2017, 15:59
A season without you winning a race would be a bit strange.
In case somebody overlooked: The last race will be delayed one week.
rjsa
rjsa
51
That'll be December 10th?
CAEdevice
52
LVDH wrote:
17 Nov 2017, 16:47
variante wrote:
17 Nov 2017, 15:59
Not as strange as a season without a 4th place by CAEdevice.
In 2016 LeMans has been my worst race, I hope to do better this year.
roon
roon
412
CAEdevice wrote:
17 Nov 2017, 11:26
garyjpaterson wrote:
17 Nov 2017, 11:17
I imagine from a structural point of view this rear wing wouldn't cope too well, with a lack of strut bearing the load. Looks epic though! :D
Yes, it is an (extreme) high downforce airfoil coupled with the (extreme) low downforce pillars... but for a graphic AC model it could be acceptable (maybe you can increase the dimension of the pillars section, to have a more realistic geometry).
Maybe add some short connectors between the pontoons and the pillars.
garyjpaterson
roon wrote:
17 Nov 2017, 22:41
CAEdevice wrote:
17 Nov 2017, 11:26
17 Nov 2017, 11:17
Something a bit like this was my thought. Apologies for the render, not imported it ingame yet.
roon
roon
412
17 Nov 2017, 23:26
roon wrote:
17 Nov 2017, 22:41
CAEdevice wrote:
17 Nov 2017, 11:26
https://i.imgur.com/v15aEYDh.jpg
https://i.imgur.com/dJUcLPLh.jpg
Yeah. Was thinking of what's sometimes found on the ends F1 RWs.
garyjpaterson
Bit of branded tyres never did any harm :)
LVDH
52
Yeah, Mantium issued standard tires. Very cool...
darkpino
darkpino
So i finally have some time to figure this all out...
I read the readme, i think i installed it the proper way but then: i use the webapplication to make myself a front wing, rear wing and floor. But in which map should i put them? Ive put them in 'special_bc' but seems thats not allowed...
Alonso Fan
darkpino wrote:
19 Nov 2017, 13:46
Either high res surfaces or vehicle body
Special bc is for engine inlets and exhausts
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
darkpino
darkpino
That did work, thanks!
when i click 'build case' it says: warning: no front wheels detected and after that i click 'run case' nothing happens. When i click post-process case it says i need to run the case first?
Alonso Fan
darkpino wrote:
19 Nov 2017, 14:00
Ah you need the cfd parts file from the challenge page. It should have wheels as separate stl files, as well as suspension etc
You'll need two extra folders in the case structure called frt_wheels and rr_wheels.
If I remember correctly wheels 1 and 2 are the fronts.
Suspensions can go in vehicle body
After you've done all this go to your parent case directory and delete everything except input_files
Create the case again
SHR Modding
Youtube
Twitter
Discord
darkpino
darkpino
Thanks! no more errors now! Only when clicking 'run case' nothing happens and at post process case it gives me the error to first run the case
Alonso Fan
darkpino wrote:
19 Nov 2017, 15:09
No problem
You need to run the case manually
Are you running Windows?
SHR Modding
Youtube
Twitter
Discord
