Oh my I didn't want to hurt you, I'm just a jealous guystrad wrote:and once again http://s22.photobucket.com/user/STRAD2/ ... e.gif.html . six pages
![Laughing :lol:](./images/smilies/icon_lol.gif)
Don't, you still have all the "motorsport journos" on your side, most of them still confusing torque with low-end power?strad wrote:I give, you are right the moon is made of green cheese
There is no unit, at least not within SI, named "kgf", Mass is kg and Force is N.xxChrisxx wrote:Xpensixe.
It's generally very clear that when talking about torque they are referring in gear pulling power from low engine speed.
No, it's not technically correct so separate low engine speed performance into 'torques' and high rpm performance into 'horsepowers'.
But then again saying that torque is completely irrelevant isn't technically correct either. Infact as we know P=Tw.
Life is full of colloquialisms.
Do you get as mental when people use the unit kg for weight and not the more technically correct kgf? Probably not.
I'm going to set out a scenario and ask you a question:xpensive wrote: The force has a relation to the engine's torque, but then you need to know the gearbox ratio, final drive and wheel radius,
why just using Force, Power and Speed is so much simpler.
Save it for the Quiz thread Chris.xxChrisxx wrote:...xpensive wrote: The force has a relation to the engine's torque, but then you need to know the gearbox ratio, final drive and wheel radius,
Think about your answer carefully.
It's not a quiz. It's just utter bullshit that you are dodging this.xpensive wrote:Save it for the Quiz thread Chris.xxChrisxx wrote:...xpensive wrote: The force has a relation to the engine's torque, but then you need to know the gearbox ratio, final drive and wheel radius,
xxChrisxx wrote: We want to work out the in gear acceleration for a vehicle with 5 gears (already pre-set, but we don't know what the ratios are). Giving it's actual acceleration profile throughout it's speed range. Assuming no slip, or traction limit.
Are you sure you don't need the overall ratio between engine speed and road speed, for you to use power force and speed.
It's not a trick, I will work through it at some point anyway. I just want to know your honest answer. No discussion involved.xpensive wrote:Not at all, I'm just not in the mood to question Newtonian mechanics, not with someone who only wants to make a point.
