Mclaren MCL40
haza
haza
Re: Mclaren MCL40
https://x.com/soymotor/status/2016472191668220298?s=46
Looks to be a hole of some description by the rear tyre
HungarianRacer
HungarianRacer
37
Re: Mclaren MCL40
des_1986 wrote:
28 Jan 2026, 13:21
HungarianRacer wrote:
28 Jan 2026, 12:55
https://i.postimg.cc/63NqRpZG/17695947297275.webp
Not to be a party pooper, but what makes this front wing "enormously more complex than any other 2026 wing" exactly? The massive downwashing canards?
In 2022, the Mercedes W13 launched with exceptionally outboard-biased front wing cord lenghts too very similar to this, yet "boring", evenly-loaded wings ended up the winning concept, just saying...
Is it just me, or are all the front wing elements connected to each other? Wonder how they'll work with the active aero?
You should discuss this with others in the Mercedes W17 thread, but yes, not only the uppermost flap is the only movable element on the Merc's front wing, it actually has a fixed middle part under the nosecone that doesn't even move at all (flap split into 3).
Others (like this McLaren) have the cord lenght generally minimized under the nosecone.
EDIT: Oh, you quoted my other comment with the McLaren image linked, I got mixed up.
No, I don't think the front wing elemnts are "connected" to eachother, maybe explain what you mean in further detail(?)
haza
haza
Re: Mclaren MCL40
monkeyboy1976
monkeyboy1976
Re: Mclaren MCL40
LionsHeart
LionsHeart
Re: Mclaren MCL40
Guacamole wrote:
28 Jan 2026, 13:24
I'm a bit underwhelmed. Bit weird to be, as it is extremely early days, I'd just expected a more visibly developed car I guess? More akin Mercedes and Red Bull. It might be a whole different car in a week or 2, it just feels a bit off?
The front wing, sidepods, and engine hood are well-designed. The rear cooling area looks taut and compact. The remaining components will be easier to develop as the season progresses. The bargeboards, floor edging, and other elements will be changed many times. It's possible the team will decide to use a mouse hole in the diffuser area.
MrGapes
34
Re: Mclaren MCL40
Looks slotted unless im looking at something else
LionsHeart
LionsHeart
Re: Mclaren MCL40
des_1986 wrote:
28 Jan 2026, 13:21
28 Jan 2026, 12:55
Good point. By magic. In official McLaren photos, a cable or metal rod is visible under the nose cone. It appears to be the connection to the upper flaps. But looking at the overall mounting, it looks like a single wing with no moving parts. It looks both curious and strange.
haza
haza
Re: Mclaren MCL40
MrGapes wrote:
28 Jan 2026, 13:35
https://imgbb.com/
Almost certain there’s a slot I can see the track through the diffuser
Re: Mclaren MCL40
haza wrote:
28 Jan 2026, 13:38
MrGapes wrote:
28 Jan 2026, 13:35
https://imgbb.com/
There's a slot in the rear part of the floor ahead of the rear tyre to renergise the rear corner of the floor, but I can't see a diffuser slot or cutout
Emag
Emag
137
Re: Mclaren MCL40
haza wrote:
28 Jan 2026, 13:38
MrGapes wrote:
28 Jan 2026, 13:35
https://imgbb.com/
You mean this bit here right? It looks a bit strange but the quality is quite bad to be certain about it. Could be a reflection.
Developer of F1InsightsHub
des_1986
des_1986
Re: Mclaren MCL40
LionsHeart wrote:
28 Jan 2026, 13:37
des_1986 wrote:
28 Jan 2026, 13:21
28 Jan 2026, 12:55
Yeah, that's what I thought. There are some pictures just posted of the car coming out of the pits and it's much clearer to see.. all 3 elements of the front wing are connected to each other with those little loop struts.. must just be a development front wing perhaps
Peter Ian Staker
Peter Ian Staker
Re: Mclaren MCL40
28 Jan 2026, 13:20
Peter Ian Staker wrote:
28 Jan 2026, 13:16
Emag wrote:
28 Jan 2026, 13:12
https://i.postimg.cc/1tBgRkzw/image.png
No slotted diffuser.
The "bargeboard's" bottom section seems segmented.
I don't think you would be able to see a slotted diffuser from this angle.
With the holes Red Bull and Mercedes cut in their's? Are you kidding me?
Here's the Merc from a more forward-facing angle:
https://pbs.twimg.com/media/G_vcBHaWYAA ... ame=medium
Nowhere near the same angle. You wouldn't be able to see the track surface through the diffuser if the Merc was as side-facing as the McLaren.
Badger
Badger
46
Re: Mclaren MCL40
You should be able to see it clearly in this picture. It's not there.
Darth-Piekus
-1
Re: Mclaren MCL40
Does it even need a mousehole? Who says they don't have another solution?
De Wet
Re: Mclaren MCL40
Looks can be deceiving. [-o< [-o<
