Team Lotus T128 Renault
nacho
nacho
Re: Lotus T128
imightbewrong wrote: Image
You can see the bulge on the sidepod here too.
bjpower
bjpower
-1
Re: Lotus T128
that cant be the side pod panel conector ( end of the side pod )
its massive.
Owen.C93
Owen.C93
191
Re: Lotus T128
I think that's there to meet the requirements of the side impact structure. Remember the F10 had a bulge infront of the sidepod (But all the way across).
nacho
nacho
Re: Lotus T128
Yeah F10 and F60 had a bulge but on the inside side. The Lotus thing looks even longer. They have wished to put the sidepods more at the back, or make them smaller. They'll probably attach the deflector there too.
Owen.C93
Owen.C93
191
Re: Lotus T128
Very steep side to the head protection as well, maybe the rest of the cockpit is very low perhaps.
Re: Lotus T128
Timstr wrote:
Blackout wrote:But why is there a single 'hole' in the fuel tank (the hole where the engine oil tank will take place) ? normally, the MGU will need a whole as well !?
MGU? Team Lotus will not be running KERS.
They said they will run Kers, but not from the beginning.
To illustrate my thoughts:
The Ferrari engine with its oil tank:
The Mercedes V8 with its MGU and tank fitted:
The T128 monocoque:
Formula None
Formula None
Re: Lotus T128
What's this?
raymondu999
Re: Lotus T128
The sidepods (what little we can see from them) seem like they've been copied from the 2010 Sauber
失败者找理由,成功者找方法
gibells
gibells
Re: Lotus T128
The sidepods seem much further forward than before.
H. Zedozil
Re: Lotus T128
Blackout wrote:T128... Interesting changes
Sleeker sidepod and got more undercut?!
H. Zedozil
Re: Lotus T128
its massive.
Scarbs on twitter: Lotus T128 Heikki's seat fitting, Note: RP steering wheel, white GPS aerial on sidepod and moulded shape to mount a sidepod fin
Tim.Wright
330
Re: Lotus T128
Formula None wrote:What's this?
Speed pipe
forty-two
Re: Lotus T128
Speed pipe
Forgive my ignorance, but what is a "Speed pipe"?
Tim.Wright
330
Re: Lotus T128
Its like a speed hole but in pipe form
[youtube]http://www.youtube.com/watch?v=XVV_COOey0E[/youtube]
747heavy
Re: Lotus T128
Formula None wrote:Image
What's this?
not 100% sure, but seeing that it has a clear pipe/tube running across it, as you usally use to check fluid levels, and what looks like a wiggins tube connector on the bottom, my guess would be header tank for the radiator/cooling system or an oil tank.
But either way, it looks a bit odd/bulky by F1 standards - IMHO
something like this, in a different shape/form perhaps:
- Colin Chapman
