I wonder if Coil-on-plug would actually make much difference to a top-fuel engine? Considering they burn their spark plugs up halfway down the track and are basically diesel engines after that....
Are there even coils that can keep up? Those magnetos are 44 amps worth of current a piece. The engines no longer have the diesel issue.
I did wonder about that.FightingHellPhish wrote: ↑14 Mar 2018, 03:46Are there even coils that can keep up? Those magnetos are 44 amps worth of current a piece. The engines no longer have the diesel issue.
IIRC it was mentioned in a conversation with someone I spoke with in the industry. The issue had been the material of the plugs but with platinum, iridium, and other things developed they were able to fix the issue at least for a single run.djos wrote: ↑14 Mar 2018, 03:53I did wonder about that.FightingHellPhish wrote: ↑14 Mar 2018, 03:46Are there even coils that can keep up? Those magnetos are 44 amps worth of current a piece. The engines no longer have the diesel issue.
Oh, how recently did they solve the plug burn out issue? Even 2 years ago this was an issue as far as I was aware.
