GoranF1
GoranF1
151
Re: Honda Power Unit
Thanks Wazari, we hope by current rate of development Honda can catch up whit Mercedes by 8th or 9th year of their 10 year contract whit Mclaren.
GoranF1
GoranF1
151
In their 3rd year of development Honda is 90-100hp down on Mercedes...can not hold 2 races whit same MGU-H and then they introduce new spec which can not hold for 2 Free practices.....and then they want Alonso out for being to critic of them.
Fantastic.
GoranF1 wrote:
08 Jul 2017, 18:40
Fantastic.
You believe those rumors that they they want Alo out? I don't. Alo has been alot nicer this weekend though.
Don't forget they moved the compressor. The MGU-H is taking the extra beating being handed out for having a longer distance between the turbine and the compressor.
GoranF1
GoranF1
151
diffuser wrote:
08 Jul 2017, 18:52
GoranF1 wrote:
08 Jul 2017, 18:40
Fantastic.
I agree mate....its juts that in 3rd year of development there is no more room for excuses by Honda.
They are not doing a good job.
Well if this update is more about fuel efficiency more than power let's see if vandoorne can finish the race without turning down the huge amount that they used to before.
bigblue
Reliability problems for a while now have mostly been MGU-H problems. Any solution coming ? Seems so far it's been "sticking plaster" kind of improvements - try to work around more fundamental problems (with only a little success) - or so I imagine. So, any more significant fix on the way, or still in the investigation phase ?
They seem to know what to look for now. it's a few times, they catch it before it happens.
amho
I've seen speed trap data and it seems that spec 2.5 doesn't give Vandorne any speed advantage over spec 2.0 although I don't know about their down force level.
After checking Alonso's laptimes in late stages of Bako gp I estimate that he lost 17 sec for fuel saving. hopefully this new update with focus on fuel efficiency at least will address the mentioned issue.
There is no Might or Power except with Allah.
tom101
tom101
-6
It's sad to remember that mgu H is still being used because of Honda.
Before 2016 season, Merc, Ferrari & Renault agreed to suppress it. But Honda voted against.
ArcticWolfie
ArcticWolfie
GoranF1 wrote:
08 Jul 2017, 18:57
diffuser wrote:
08 Jul 2017, 18:52
GoranF1 wrote:
08 Jul 2017, 18:40
Fantastic.
They changed their "size zero" engine design after 2 years because it didn't work, this "new" design should be much better for the future.
PlatinumZealot wrote:
08 Jul 2017, 19:43
Agreed, I think the car is reasonable in the race, it just lacks endurance to run at it's optimum setting. Very reminiscent of 2015 where the car would be able to tangle with the midfield until they ran out of battery power. If this improves it will be a decent step forward, I imagine efficiency and power will all come together slowly but surely.
479
08 Jul 2017, 19:43
Are they not two sides to the same coin?
More power gives you more fuel efficiency because you are not using any more fuel but you are going faster.
Peak power numbers is what people like to look at so it easy to forget about the rest of the curve and all the other device interplays. Power is nothing without control they say... So i am assuming that they can now run the same power for longer bearing in mind they had to turn down for reliability from the very begining and also MGUH generation was not that great.
kaepernickus
wuzak wrote:
09 Jul 2017, 03:08
08 Jul 2017, 19:43
That's only one option.
You could also lower fuel consumption while keeping power output about the same.
Doesn't help that much with one lap, but can be very good for race distance as you can run the higher power modes for a longer time.
henry
324
kaepernickus wrote:
09 Jul 2017, 06:46
wuzak wrote:
09 Jul 2017, 03:08
08 Jul 2017, 19:43
I genuinely don't understand how this works.
I can only think of two ways to reduce power.
1. Run a lower fuel rate than is allowed.
2. Run the allowed fuel rate with lower efficiency.
What am I missing?
