GoranF1
GoranF1
149
Re: Honda Power Unit
Austin or Mexico for update..... :D :D :D
LOL....better get it at winter test 2018
etusch
131
GoranF1 wrote:
15 Jul 2017, 21:52
What?
Japanese are known for great bearing technologies. It's ironic Honda has succumbed to so many bearing issues over this year alone. Premature wear of the MGUH bearings was the last issue. Could be improper bearing selection more than a design fault in the housing. They simply changed the bearings out to better ones.
Macklaren
Macklaren
PlatinumZealot wrote:
15 Jul 2017, 22:44
could also be that they are pushing the envelope like its never been pushed before!
makecry
makecry
19
Macklaren wrote:
15 Jul 2017, 23:23
15 Jul 2017, 22:44
I would agree with that if it was like the indycar engine which is fast and before they found out the solution had reliability issues because of "pushing the envelope". In the F1 PU, however, it's neither fast nor reliable so I dont get pushing the envelope argument at all.
GhostF1
GhostF1
112
I think we are just seeing solid incremental improvements with the new spec PU. Hasegawa said they are making progress with the mapping in the new engine with each outing and each GP. So every little bit helps. They're showing good pace at Silverstone, I thought they'd struggle pretty badly.
damager21
damager21
GhostF1 wrote:
16 Jul 2017, 00:55
It will be interesting to see if both Alonso and Vandoorne are required to save fuel during the race. As per Wazari-sans comments, spec 3 is more about improvement in combustion efficiency rather than increase in peak output.
If drivers don't need to save fuel like before, I expect a good race for both else they will very quickly fall behind. So key things to watch out today
1. Reliability of engine and specifically MGU-H
2. Fuel saving
If above 2 are good, expect some points for McLaren at Silverstone which will be pretty sweet at their home GP. Points at Silverstone and Hungary will be great for the team before summer break. WIll keep enough boost for Honda to push like crazy for their next update
63l8qrrfy6
63l8qrrfy6
368
No power
Joseki
Joseki
Usual reliability update called for PR reasons that brings nothing.
I saw no smoke coming out of the engine, so it's presumably the MGU-H again.
I'm seriously thinking that doing something so wrong for so long is probably more difficult than doing it on purpose.
GhostF1
GhostF1
112
Joseki wrote:
16 Jul 2017, 15:02
Not entirely surprised. It was an old unit with a "fix" applied to it that apparently didn't cause penalty... It stunk of issues from the get go.
Oonnnn
Oonnnn
I heard Crofty said it's a loss in fuel pressure. Correct me if I'm wrong though.
Marti_EF3
56
Fuel pump issue. It's a Honda failure? Or Mclaren?
HPD
198
Alonso: "The petrol pump is the official version, it made us lose power" (Movistar)
Much better the consumption in this race, this is a step forward
etusch
131
one step forward more and they are 4th fastest as they were last years end. Not in terms of point but in terms of pace..
drunkf1fan
drunkf1fan
etusch wrote:
16 Jul 2017, 16:19
4th fastest, despite Renault, RBR, Mercedes and Ferrari all being ahead here, it was one race and they need a massive step. 4th fastest with a car that fails to finish every other race isn't 4th fastest. You're 4th fastest when you can finish the year as 4th fastest car, not when average over a season is 7th fastest because you are 4th in some races and dead last in others because you can't finish. Silverstone probably has more time on throttle in corners than most rather than all on straights so Silverstone isn't nearly as bad as people think it is for Mclaren/Honda.
Honda have 2-3 steps on performance and 10 steps to make on reliability before they can consider being the 4th fastest car.
