Why is this causing such an issue?
If the engine is situated between the two axles, it's mid-engined.
Simples.
But for example the old Citroen DS is called mid-engined too but it has the engine between the driver and the front axle.rjsa wrote:I'd assume the engine ahead of the driver would me considered a front engine disregarding it's position relative to front the axle.
Like I said above, I just got educated on the matter.piast9 wrote:But for example the old Citroen DS is called mid-engined too but it has the engine between the driver and the front axle.rjsa wrote:I'd assume the engine ahead of the driver would me considered a front engine disregarding it's position relative to front the axle.
We got into the discussion because rjsa insisted that Ferrai's front engined F1 cars were succeeded by mid engined cars in 1960 and not rear engined as I have said.ringo wrote:Why are we discussing this?![]()
How about the bore and stroke of the 1.6lt engine, what can we expect?
return of flywheels?
82.4/50 V6 at 12000 rpm, with 50 cc/sec fuel-flow restriction.WhiteBlue wrote: It will be interesting to see how close I can hit to the real values. Anyone else who wants to take shot?
