My point was - ultimate race-distance fuel is indeed fixed at 100kg, or whatever it is.
However I'm quite sure Car A and Car B, two cars identical in everything except for downforce, you would not complete a lap with the same fuel consumption rate. Remember that the two cars are identical even in engine maps and modes. So first question is - which would use more fuel? This initial question is posted, regardless of 2014 regulations.
Now for the 2014 fuel regs...
Depending on the answer to part a above, one car would have to run slightly leaner/richer than the other to fully comply with the 100kg/race limits. Ultimately both will use equal fuel of 100kg over the race distance (assuming neither are lapped by the other) but I am putting forth the hypothesis that given the different df levels, they will run different engine modes to achieve said fuel consumption target over the race distance.
