Most pec...bizarre aerodynamics thread.
Scardini1
Scardini1
Re: Most pec...bizarre aerodynamics thread.
Are there any regulations that would prevent a Delta Wing type design from appearing at F1? The underbody aerodynamics alone would be a deal-killer at first glance.
Lycoming
Lycoming
106
Scardini1 wrote:Are there any regulations that would prevent a Delta Wing type design from appearing at F1?
There are many.
Covered wheels are not allowed
Front wheels that narrow are not allowed
The extreme rear weight bias is not allowed
It also violates several bodywork rules, including but not limited to:
3.7.1
Aside from that, there are more practical limitations, such as:
-it would be difficult to get adequate cooling for the 2014 powertrains within the tiny body of a deltawing-like design, which originally housed an engine with much lower heat rejection requirements. They had quite some difficulty getting it to not overheat the 1.9l elan engine.
-not having wings makes it hard to adjust aerodynamic balance and change drag/downforce betweeen tracks
-Pirelli doesn't supply a bicycle tire for the fronts
-You'd be giving up DRS
-You can't capitalize on the weight advantage of the design because of the minimum weight
xpensive
xpensive
214
xpensive
xpensive
214
Found this on the web, obviously a Tyrrell 011 (1981-83), anyone who knows more about it, a primitive diffuser perhaps?
zonk
zonk
69
Source: AUTO hebdo n°351, January 13th 1983
xpensive
xpensive
214
1983, the first year with the flat bottom rule, picture dated Januari 13th, the above might be the very first diffuser?
But check this out, back in 1974 they knew how to make a decent scoop!
Osella
FW17
168
Adams Escort Can-Am
FW17
168
FW17
168
FW17
168
McMrocks
McMrocks
32
Blanchimont wrote:
Some motorcycle aero:
http://www.speedzilla.com/forums/street ... force.html
Just out of curiosity, do wings that generate downforce make any sense on motorcycles?
I'd say they don't make any sense when the leaning angle is more than 45°. Because when the angle is more than 45° the downforce will push the motorcycle off the track rather than pressing it on the track. #-o
nacho
nacho
It doesn't make sense for providing grip in corners unless the wings are active and stay perpendicular to ground.
FW17
168
nacho wrote:It doesn't make sense for providing grip in corners unless the wings are active and stay perpendicular to ground.
Wings need not be perpendicular to the road.
xpensive
xpensive
214
Perhaps the wings should be applied radially to counter centripetal forces, F = m * v^2/r, in the corners? :idea:
