alexx_88 wrote:I'd love to see evidence of an ECU calculating the fuel flow over a short enough period of time to be considered instantaneous with an accuracy of 1% as is the one stated by Gill and without any correction factor programmed into it. It boils down to the question: if you put a 1ms pulse over a 10cc/second injector, do you get exactly 0.01cc of fuel each time?
What I bet is that, all the engine manufacturers have correction factors on the simple math that is SUM(injector_pulse_width * injector_size) which yield, for that engine a more accurate fuel rate value. The FIA needed the same measure tool for all, thus the the flow sensor. If every team gets 10 of them, tests them and uses the one which they like most (reads the lowest) then it's a level playing field.
It is direct injection so 1 ms is a long time, the whole compression stroke at 10krpm is 12ms
the flow through the injector will depend on the differential pressure, so will opening and closing times and it direct
injection so it isn't just fuel pressure vs. ~1bar like manifold injection it is fuel pressure vs. cylinder pressure
opening time will also depends on the voltage driving the injectors.
And I don't see why the teams, other than for the flow restriction, need an absolute flow flow number, they need
injections to be consistent so the engine can be tuned to the correct mixture
