bonjon1979
bonjon1979
30
Re: Honda Power Unit
bonjon1979 wrote:
21 Feb 2018, 16:23
restless wrote:
21 Feb 2018, 16:12
1y ago in Australia there were severe upshifting problems with the engine&transmission
Is that what we're hearing in that video?
Here's the sound in Australia 2017 free practice.
https://www.youtube.com/watch?v=e2V7NFz8Qzo
Sounds much worse in this video but it's definitely the same vibration on upshift.
dren
226
delete
Honda!
It runs!
etusch
131
a good start to new partnership
Maritimer
Maritimer
19
The fluttering is caused by the gearbox isn't it? You used to hear it quite a bit with the V8s. Driveline shunt yeah?
ArcticWolfie
ArcticWolfie
It's difficult to tell because;
-Bad weather
-New exhausts
-How good is the recording mic?
We will see next week.
Roostfactor
Roostfactor
They may have tuned it that way to make sure the shakedown went smoothly. I will look for tighter shifts as testing progresses. JMHO.
Not even pushing.
GhostF1
GhostF1
110
Sounds so different! Things are getting exciting!
Could be a bit of engine mapping too. Need Wazari to confirm what it is.
GhostF1
GhostF1
110
PlatinumZealot wrote:
21 Feb 2018, 22:24
Agreed, surely some calibration going on. This is the first time the Honda PU has used a completely different gearbox. But I also wouldn't mind a quick pre test Wazari update 😏
Wazari
623
I really haven't heard anything that's newsworthy IMO. I hear everything is on track, going with slightly more conservative "4.1" PU at season's start. Rumored that at least one "version" of built PU has exceeded 700 kWh but just a rumor...........
-- Honda Soichiro
kfrantzios
kfrantzios
46
Wazari wrote:
21 Feb 2018, 22:46
700kW is less than 940hp... I guess that version doesn't excell in terms of reliability
GhostF1
GhostF1
110
Wazari wrote:
21 Feb 2018, 22:46
That's fair enough actually. Conservative start is probably a smart move. Keep things rolling at decent but safe pace while development continues for down the line.
Curious about the "one version" line. Are you talking like a spec 4.2/3/4/5? Or are you suggesting one of the 4.1's built has hit 700 on the dyno?
McMika98
McMika98
-24
Wazari since you said that Honda have identified new combustion process which others cannot copy. What do u think the likes of Renault are doing to get over 950 hp at the beginning of the season? Merc were doing it last year. I had a feeling anything less than 950 was trouble for Honda and it appears they have not delivered again at the start of season.
