3+ years ago I asked that question - ie is it possible to control directly the rate of heat addition by controlling the rate of injection ?basti313 wrote:Can you please explain, what you mean with "quasi detonation state"?godlameroso wrote:Well according to what has been discussed and speculated in the Mercedes power unit thread is that, they might be using a form of gasoline auto ignition. And given Boullier's comments about tuning with knock, I'm beginning to think that they are trying to run the engine on some quasi detonation state.
To my understanding the main benefit of auto ignition is, that you do not have anything like pre-ignition. The fuel completely ignites once it is pushed into the combustion chamber. So there will not be any knocking problems on an engine with auto ignition.
(ideally, regardless of whether combustion is spark-initiated or otherwise ?)
diesel fuel is rated for ignition delay (Cetane No) - the delay helps
but presumably gasoline also has some delay (eg in self-ignition),
some self-ignition after the spark in not unknown in high-power engine operation, it may help a race engine
