2016-2017 chassis and engine rules (proposed)
FW17
168
Re: 2016-2017 chassis and engine rules (proposed)
"The current problem revolves round engine costs and supply," he explained. "The solution would be rules allowing only two engines per car per season.
"This would simultaneously double supply and halve costs. Today's engines would require only a modest adjustment to achieve that.
"The engine suppliers would immediately say it was impossible and would be a disaster, but in the history of F1 there has never once been a case where such predictions have proved accurate".
- Max Mosley
Fer.Fan
Fer.Fan
scarbs
scarbs
393
Fer.Fan wrote:http://www.formula1.com/content/fom-web ... -2016.html
Interesting!!! =D> =D> =D>
That was published before the regs fixed the wastegate tailpipe position into the same area as the main exhaust.
Pingguest
Pingguest
FW17 wrote:"The current problem revolves round engine costs and supply," he explained. "The solution would be rules allowing only two engines per car per season.
- Max Mosley
If reducing the number of power units per season is indeed the right solution, why not allowing just one power unit per season - as is the case in DTM?
ME4ME
79
It would mean no in-season development.
Pingguest
Pingguest
ME4ME wrote:It would mean no in-season development.
That would indeed be a consequence. But with the engine usage already being limited, so is in-season engine development, regardless the existence of any so-called token system.
bhall II
bhall II
473
Max Mosley, the man who brought us grooved tires, isn't the brightest bulb when it comes to technical matters. It's the cost of development that makes power units so expensive, and development costs cannot be curtailed by production limits.
j2004p
j2004p
bhall II wrote:Max Mosley, the man who brought us grooved tires, isn't the brightest bulb when it comes to technical matters. It's the cost of development that makes power units so expensive, and development costs cannot be curtailed by production limits.
=D> =D> =D>
Well said, can you imagine the amount of money they'd pour into pre-season development?
djos wrote:The wider rear tires and bigger rear diffuser certainly look a lot better, Im not sold on the rear wing tho. It would have been better if they just made this years RW wider imo.
My first thoughts as well. I have grown to like the high rear wings.
Rules limit the exhaust pipe positioning now
FrukostScones
162
Omnicorse.it: 2017 rules could make for very different looking solutions/cars:
https://translate.google.de/translate?s ... t=&act=url
Pingguest
Pingguest
=D> =D> =D>
Assuming engine manufacturers do not wish to start the season with an uncompetitive engine, their pre-season spending on development is sky-high already. Mid-season engine development is just to gain an even bigger advantage or to close a gap they were confronted with.
void
How about more aerodynamic freedom for those teams that chose FIA engine, and more restricted to FOM engine.
Indeed the unit cost goes up if you introduce production limits. And that means that the other teams will struggle even more to pay for their engines.
That's why mass production was invented...
ScottB
ScottB
void wrote:How about more aerodynamic freedom for those teams that chose FIA engine, and more restricted to FOM engine.
Penalise the manufacturer backed teams in favour of a proposed, cheap, simple customer engine and the manufacturers will leave. If it isn't better than the current engines, nobody will want to run the customer engine.
Why it won't get off the ground in a nut shell, basically!
