Awesome! Before we get started trying to develop the car I thought it worth posting a few images which should help further to understand why we get the surface pressures we do, and therefore how we can avoid or promote pressure in the appropriate places:
When the air passes the car it changes speed and direction. Bernoulli tells us that if the speed increases the static pressure on the local bodywork decreases, and Newton tells us that when the speed and direction of motion changes we should see an equivalent force in the opposite direction to those changes. The pressures over our car are as a result of those two effects.
IMAGE 1: If we first take a teardrop shape this means that as air first encounters the shape the air has to turn away from the leading edge, creating a longitudinal force backwards on the object. As the air travels around the top and bottom (or sides) it accelerates and changes direction, causing low pressure on both sides of the object. This low pressure cancels eachother out so we get neither lift nor downforce, and get only drag.
IMAGE 2If we change the shape of the teardrop so the upper surface is largely concave then we now get a downward force on both the upper and lower surfaces (on both sides the air is directed upwards), so the net effect is downforce (and drag).
IMAGE 3If we cut the teardrop in half we only have the upper surface, therefore overall we get lift and drag (The low pressure on top is no longer balanced by the low pressure underneath, because there isn't any low pressure underneath!)
IMAGE 4Finally if we change our shape to replicate our car's underside (a very simple model!) we can see that the air turns at the leading and trailling edges (creating force in accordance with Newton) and we also (hopefully*) get an increase in speed underneath due to the lower cross-sectional area under the floor. This produces a low pressure in accordance with Bernoulli. (The same low pressure is also trying to "suck" up the ground which is why manholes at Monaco are welded in place).
*Now I've said "hopefully" because if the flow-path is too restrictive we might actually observe the flow slowing down and therefore experience an increase in pressure under the floor! It is the determination of the direction and magnitude of the air as it passes around our object which is the difficult part and why we turn to CFD....
OK... now we can look over your CFD images....
