FPV GTHO
FPV GTHO
Re: Renault V6 Power Unit
Renault must be losing alot of performance through the turbo through the year, if even at so much lower than the max RPM theyre having reliability issues. I expected Renault to be the ones running at max RPM
noname
noname
FPV GTHO wrote:
06 Nov 2017, 02:55
108.000 RPM is reasonable good result for them. Their turbo from the very beginning (2014) was running slow. It (was) not necessary bad thing considering its sizing.
Quantifying the gap can be tricky, however 2 years without major developments for sure does not help. Especially when both Merc and Ferrari put significant efforts into their turbos.
hurril
hurril
noname wrote:
06 Nov 2017, 12:17
FPV GTHO wrote:
06 Nov 2017, 02:55
This is certainly true. How do we know about the Mercedes and Ferrari RPM:s though?
noname
noname
hurril wrote:
06 Nov 2017, 12:26
People in F1 are moving around all the time. And there are plenty of partners and suppliers involved.
wonk123
wonk123
Jejking wrote:
05 Nov 2017, 23:17
baybars wrote:
05 Nov 2017, 20:17
Renault’s woes were track-specific
http://www.f1technical.net/news/21434
Renault let its turbochargers run at 108.000/min at the beginning of the weekend. As the engineers found out after the early issues experienced during the practice sessions that this running value it too high, the rev speed was decreased to 102.000/min for the race. This decrease meant a loss of 0.15 of a second in pure lap time.
Interestingly, Ferrari could run its turbochargers at the maximum of 125.000/min while Mercedes was only a tiny bit below that limit.
Why would Mexico cause problems? The circuit seems to be reasonably smooth so it probably has nothing to do with the bumpiness. Ambient temperature might have been problematic, or the altitude?
I assumed that the turbo was run at higher rpm to make up for `the higher altitude. More rpm would keep the engines at approximately the same HP as at sea level. However they did not cope with the forces involved
That is actually very interesting, I was curious for a long time as to what turbo RPM manufacturers ran.
MHR650
MHR650
In the turbo industry nobody uses RPM, what is important is tip speed of the compressor wheel in meters per second. A turbo spinning 108,000 rpm can have a much higher tip speed than one running 125,000 depending on the size of the wheels. For reference a really small turbo like from a 3 cylinder Smart car spins more like 300,000.
63l8qrrfy6
63l8qrrfy6
368
MHR650 wrote:
06 Nov 2017, 17:46
Nonsense, shaft speed drives mechanical loads. What do turbo speed sensors measure in the turbo industry ?
noname
noname
Mudflap wrote:
06 Nov 2017, 21:42
MHR650 is right in saying tip speed matters. Although it is much easier to measure RPM, but you do need to know what wheels are inside. Quite often compressor maps are showing tip speed, not RPM.
Good luck in trying to spin this beauty to 100.000 RPM :)
http://www.motorship.com/__data/assets/ ... harger.jpg
BTW, also in this department Renault falls behind.
63l8qrrfy6
63l8qrrfy6
368
noname wrote:
06 Nov 2017, 23:00
Mudflap wrote:
06 Nov 2017, 21:42
I've not said it does not matter. Also, most compressor maps I've seen plot shaft speed rather than tip speed.
Secondly the point of the conversation was the effect of turbo speed on reliability. In that respect tip speed is almost meaningless (particularly when the wheel diameter is unknown) while shaft speed is much more relevant as unbalance loads increase with the square of angular velocity.
noname
noname
Mudflap wrote:
06 Nov 2017, 23:11
(...) the point of the conversation was the effect of turbo speed on reliability. In that respect tip speed is almost meaningless (...)
"Almost" makes a difference
https://www.youtube.com/watch?v=7Y01Ed4Sg3U
FPV GTHO
FPV GTHO
MHR650 wrote:
06 Nov 2017, 17:46
The regulations stipulate max rpm though, so its relevant for that fact alone.
And if there's a suggestion Renault dont need to match Mercedes and Ferrari's rpm as they possibly have a larger turbo, i think you're dreaming.
63l8qrrfy6
63l8qrrfy6
368
noname wrote:
06 Nov 2017, 23:38
Mudflap wrote:
06 Nov 2017, 23:11
Rotational energy dissipated in the impact is 0.5 x inertia x shaft speed ^ 2. Where is the tip speed in that ?
621
additional to these various difficulties of the (unplanned ?) need to race at 2200m altitude by raising the turbo rpm ......
there would be electrical difficulties as the H generation and motor action requires at least a correspondingly raised excitation frequency
445
FPV GTHO wrote:
06 Nov 2017, 23:46
MHR650 wrote:
06 Nov 2017, 17:46
The regulations stipulate the maximum rpm of the MGUH, not the turbo. The MGUH can be geared up or geared down from the turbo.
