F1 2016 pre-season testing
the EDGE
the EDGE
67
Re: F1 2016 pre-season testing
mikeerfol wrote:
the EDGE wrote:
mikeerfol wrote:In case you didn't see it at the McLaren thread, someone is doing a live stream on periscope https://www.periscope.tv/w/1OyKAzNazOgGb
I have no idea how u found this, but very well done, sounds amazing, the picture could be better, but i'll happily settle for this over nothing at all. Adds a great 'theme' tune to my days F1 website surfing =D> =D> =D>
Someone posted it on Autosport forums :)
if it was that easy...i take it all back :lol:
One good thing about the Renault being basically last years car - it gives us a good baseline to compare progress against for the other cars :)
The new Ferrari engine sounds very much like last years Honda off-throttle, maybe Honda's ICE really was as good as they said?
domh245
domh245
30
PhillipM wrote:One good thing about the Renault being basically last years car - it gives us a good baseline to compare progress against for the other cars :)
It may be wastegate related?
ESPImperium
ESPImperium
64
Is F1.gr doing the live timings this year so to see who is doing the most consistent lap times?1
Would be good to see those this year!
mikeerfol
68
ESPImperium wrote:Is F1.gr doing the live timings this year so to see who is doing the most consistent lap times?1
You mean msfree.gr? No, they don't...
Red flag! Caused by Grojean apparently
bauc
First red flag of the day, most probably Grosjean's front wing has fall off on track
FrukostScones
162
they should of machined it
uh a a a
Vasconia
Morteza wrote:Red flag! Caused by Grojean apparently
Yes, it seems that he has lost the front wing.
ChrisF1
ChrisF1
First test for Haas, wonder how many times they've done a simulation of what, unless driver error was the cause, you would assume was a structural failure. Check the loads through the wing, define the cause...
At least it didn't go under the car and cause significant damage - wouldn't have been good to happen down the front straight.
Jef Patat
Jef Patat
I'm looking at this one: http://en.f1i.com/live/
FrukostScones
162
from autosport live:
12:28 Initial impressions of the new Ferrari from trackside are quite positive. Vettel was on the medium tyre and not exactly going all out, but the car looked fast, stable and transitioned well from turn 2 to the entry of turn 3 with Vettel able to take a nice tight line. The McLaren looks similar but a bit more on the edge through 2. The Toro Rosso also looks strong but with a wider angle of attack at 3. The Haas looked solid in the laps it did. Similar to the old Sauber but with more flexibility on the line Grosjean could take into 3. At least before the front wing fell off!Ben Anderson
ME4ME
79
ChrisF1 wrote:First test for Haas, wonder how many times they've done a simulation of what, unless driver error was the cause, you would assume was a structural failure. Check the loads through the wing, define the cause...
But it did happen down the start/finish straight. And were do you suppose the front wing to go at 250 km/h other than under the car? I think thats pretty much what happened. Doesn't mean they damaged much though. The front wing probably got crushed into a thousand bits.
dobbster71
Typical American build quality :D
WRC is for boys. Group B was for men!
Juha Kankkunen
