2021 Engine thread
Big Tea
99
Re: 2021 Engine thread
mzso wrote:
24 May 2019, 00:21
JordanMugen wrote:
01 May 2019, 12:25
ACRO wrote:
28 Apr 2019, 11:44
this resulted in extreme high reving screamers where the sound was just a pure side effect of a 'non efficient' engine throwing vast amounts of unused energy thru the exhaust .
Not so fast!
If the sound was a mere side effects F1 cars could easily have been fitted with mufflers and required to comply with strict trackside noise limits, just like other racing classes. Yet somehow the requirement for muffling is waived... Surely there is some reason for that? :wink:
Mufflers decrease performance, don't they?
If everyone has them there will be no difference. Possibly increas the flow limit if time is the target
SectorOne
Zynerji
110
My thoughts are towards going back to the NA 2.4v8 DI/TJI (Frozen at the end of 2022), twin Unlimited GU-H on the exhaust, Unlimited MU-K on engine, and front wheel Unlimited MU-K hub motors. No Battery, just a small Supercapacitor bank for balancing. Move to LNG, with fuel "pods" that can pop-and-swap during a pitstop.
Noise (RPM), power(torque), direct GU->MU drive(no trickery). Put triggers on the steering wheel that gives the driver the ability to "boost" an individual front wheel during cornering for another driver-input dimension.
I can always dream... :mrgreen:
roon
roon
412
Makes sense. If F1 is to stick with hydrocarbon fuels I can see them simply reducing the flow rate in subsequent years. That much has been suggested here on the forum often. Electric valve train is interesting. I suppose they mean solenoid/linear motor actuator valves, not a motorized camshaft.
Maritimer
Maritimer
19
What's to stop them from using pneumatic actuation a la free valve Koenigsegg have developed?
AJI
AJI
27
2 stroke! I'm surprised. They should allow rotary valves too
446
Zynerji wrote:
28 May 2019, 19:58
They couldn't just update the old 2.4 V8s, they'd have to start again.
The old V8s weren't DI, let alone TJI. Also not sure how well TJI would work with a N/A engine.
Twin MGUHs would muffle the sound and cause back pressure that the old V8s couldn't handle.
I expect that the proposed engine would lose 100hp over the current configuration and, possibly, weigh more. If they are to meet the fuel flow regulations in current use, the power loss could be more.
No battery means no boost where the cars need them the most - out of slow corners.
Why LNG? Why not hydrogen, produced from electrolysis from renewable energy, of course?
621
wuzak wrote:
29 May 2019, 08:31
...Twin MGUHs would muffle the sound and cause back pressure that the old V8s couldn't handle.
....No battery means no boost where the cars need them the most - out of slow corners.
well ...
isn't exhaust turbine-recoverable power ('blowdown power') available without back pressure ?
isn't electric motoring not much used at low speeds as the car is then traction-limited even on ICE power alone ?
though NA MGU-H has less to gain from heat dilution (leaning) as that would tend to increase ICE size and some losses
Dr. Acula
Dr. Acula
46
Tommy Cookers wrote:
29 May 2019, 10:06
well ...
Well, simply put no. A turbine in the exhaust stream is comparabel to a substantial reduction of the cross section of the exhaust pipe. It will always lead to a pressure increase upstream.
We had some discussions in other threads about that. In my opinion they can use as much electric power as they want at any time as long as it doesn't violate some specific rules, which means they can potentially use the full power of the MGU-K out of a slow corner and scale back the poweroutput of the ICE accordingly which will be the most efficient way to drive.
Using a lot of electric power at high speeds would be a waste in my opinion, at least as long as you don't have enough energy available to use it all the time.
If i remember it correctly you need 8 times the power to achieve the same acceleration at twice the speed. That's why it's way better to use as much electric power as possible at low speeds.
Zynerji
110
wuzak wrote:
29 May 2019, 08:31
Zynerji wrote:
28 May 2019, 19:58
Just the heads, probably a derivative of the current v6 tech. They have already proven bulletproof reliability of their V8 short blocks. By updating the short block with the current V6 head technology, I believe they can get 20000 RPM pretty reasonably at a good fuel consumption. The real question is, does TJI have any benefit in a non boosted engine, and does the VLIM supercharge enough to offset this restriction.
Hardly. Please provide math/proof since you are stating this as a fact. And these are GU, not MGU. We currently have 6 into 1, where my idea would have 4 into 1, but half the size. And 20000 RPM instead of 12000 should overcome this concern. Even running twin, current sized units at 1.2L each, instead of 1.6L would probably work as you are deleting the work done by the compressor.
2.4l v8 was about 875hp, 225ft-lb @ 18000rpm. Adding another 200-300hp through the GU-H -> MU-K would increase low end torque, and high rpm power. Battery loss saves huge amounts of weight. Front Hub motors will add about 7kg to each wheel. I think my suggestion would still come at a net lowering of weight, and a net increase of tractive power from AWD.
Any fuel that makes sense in a pit-swappable, pressurized "pod" is fine. I'm just after the safety of quick change fuel. Anything that allows the cars to carry less fuel while on track will help the tyres by decreasing the variance of the full fuel weight and the low fuel weight. That will allow the teams to dial in the tyres far better I believe. This would also remove parts like fuel pumps and such.
saviour stivala
saviour stivala
Comes 2021 and you lot will find that a lot of time and space had been wasted on this here subject wish list because the present engines/power units used will be exactly the same. So it’s best to change the subject to at minimum 2025.
621
Dr. Acula wrote:
29 May 2019, 13:50
29 May 2019, 10:06
well ...
my point above was put as a question out of politeness to wuzak
blowdown power is in practice available without increase in mean exhaust pressure aka back pressure
according to the Wright company brochure in addressing this point of contention
BP is there in the exhaust pulses (to the extent that these have been preserved by design)
Wright engines (and NACA data with NA blowdown recovery) show potentially 8 - 10% 'free' power is available via NA BP
(though exhaust pulses of a V6 with 2 turbines are better suited than those of a V8)
yes I have suggested there may have been exhaust system factors flattering the Wright and NACA results ....
but Wright clearly sacrificed BP recovery in favour of practicality eg 18 cylinders sharing 'only' 3 PRTs
F1 is quite suited to NA BP recovery
the power requirement (and so the recovery turbine requirement) being rather steady - unlike a road cars' requirement
there can be some question of whether the recovered power route should be electrical or mechanical or both
Big Tea
99
So would a 3 cylinder triple turbo with 3 pipes be more efficient? Or would the difference be tuned out?
Zynerji
110
29 May 2019, 18:36
Dr. Acula wrote:
29 May 2019, 13:50
29 May 2019, 10:06
well ...
I wouldn't be against a 2.4Lv6-NA-DI-TJI-VVT with the twin GU-H, integrated 300kW MU-K and 18000+RPM with 120kW hub motors in the front wheels. A 1200eHP-AWD formula?? Yes, please!!
The real question then becomes about how far you could push the GU-H/MU-K if the design specialized in ONLY recovery/deployment instead of the hybrid MGU tech. I may be open to ammending my "dream" idea to include MGU-K front hub motors if we can get a counter-rotating twin MLC flywheel in the nose for recovery/storage/stabilization... [-o<
446
29 May 2019, 10:06
It is, or at least minimal back pressure increase. It won't provide the recovered power he is dreaming of.
29 May 2019, 10:06
In the current cars yes, because they have shed loads of low down power.
The N/A V8s, however, do not have nearly the same amount.
