Alonso Fan wrote: ↑31 Jul 2017, 06:00
Just ran another simulation using blueCFD and i cab say that all the numbers are now there when post processing but i am not getting all the plots.
I have no pressure plots and no contours at all. I do have the velocity plots, the bare car, see through car and the weird red warped stuff. That's it.
Also i would like to ask if the case.foam file is openable in paraview? If so, which version should i use? My paraview currently doesn't even recognise all stl files and its not importing geometry if i open the foam file
One issue with your case is that the stl files have capital ".STL" ending. I have taught my software to deal with this, but the post-processing has an issue. That is why so many images remain white, and the warped red stuff would also make more sense when you would see your car with it. I will simply tell my software to automatically rename stl files ending with ".STL" to ".stl". That should then fix all these issue once and for all.
You can upload your case include log files to Dropbox and I will have a look.
That your Paraview also has issues, is because of an issue with VTK, which is used by Paraview. I have tried to tell them about it but they did not answer. You can try to open the stl with some other software and save it differently.
etsmc wrote: ↑31 Jul 2017, 06:38
Would anyone else be willing to test the suspension geometry in the vehicle_body folder and also in the High_res folder?? for me the simulation with it in the high_res folder always fails.
