[MVRC] Mantium Virtual Racecar Challenge 2017
machin
162
Re: [MVRC] Mantium Virtual Racecar Challenge 2017
CAEdevice wrote:
21 Oct 2017, 14:59
@Machin: what about Indinapolis? "Efficiency" or "extreme low df" track?
I'd have to make the model to find out, but I'd guess "efficiency" since those cars are travelling around the corners really fast, so downforce would be a huge advantage...
I agree with LVDH's suggestion; if we can tie in the MVRC to real races then hopefully it might increase media coverage..
CAEdevice
LVDH wrote:
20 Oct 2017, 21:33
Well, I cannot reproduce or confirm the issue but I repacked the Windows version and uploaded it a while ago. If the issue persits I will have to request a case from one of you guys.
With the repacked version the PP works!
rjsa
rjsa
51
neve mind
rjsa
rjsa
51
CAEdevice wrote:
22 Oct 2017, 10:37
LVDH wrote:
20 Oct 2017, 21:33
You managed to PP a previous run or did it all over?
CAEdevice
rjsa wrote:
22 Oct 2017, 12:03
CAEdevice wrote:
22 Oct 2017, 10:37
LVDH wrote:
20 Oct 2017, 21:33
It was a new simulation, I don't knw if it works with an old one.
etsmc
etsmc
Don't know if this is even possible or how much it would affect the results or simulation time, A moving floor?
I had read that a moving floor in a simulation could have an impact on the performance of the floor and diffuser area.
CAEdevice
@LDVH: Hi, I still have problems with the post processing (it happens randomly): I am uplading the whole case and I will send it to you
LVDH
45
etsmc wrote:
23 Oct 2017, 02:47
It sure does, that is why we have that.
CAEdevice wrote:
23 Oct 2017, 09:11
I will check it out.
LVDH
45
Just an update for everyone holding off the installation of the 2017.10 version with the rotated radiators:
Matteo's case works for me, so I guess he simply runs out of memory or something else specific to his setup.
rjsa
rjsa
51
LVDH wrote:
23 Oct 2017, 16:22
It doesn't work here either.
LVDH
45
rjsa wrote:
23 Oct 2017, 16:36
LVDH wrote:
23 Oct 2017, 16:22
Excellent, although I guess you once more created the case on Windows, executed on Linux and post-process on Windows again. This does not work. I will fix this though right now. Other than that I have offered to add your workflow to the HPC tab, so everyone could use AWS. If you ever want to accept this offer, we can do the work.
rjsa
rjsa
51
LVDH wrote:
23 Oct 2017, 16:39
rjsa wrote:
23 Oct 2017, 16:36
LVDH wrote:
23 Oct 2017, 16:22
Nope, this is 100% windows.
rjsa
rjsa
51
LVDH wrote:
23 Oct 2017, 16:39
That happens when I send to AWS. This is all home.
rjsa
rjsa
51
rjsa wrote:
23 Oct 2017, 16:54
LVDH wrote:
23 Oct 2017, 16:39
I didn't really see the offer, yes let's try it. how exactly can I collaborate?
LVDH
45
rjsa wrote:
23 Oct 2017, 16:53
LVDH wrote:
23 Oct 2017, 16:39
rjsa wrote:
23 Oct 2017, 16:36
OK, bad news then. I am investigating together with Matteo what is wrong with his case. Maybe you have the same issue. I will first fix his stuff.
rjsa wrote:
23 Oct 2017, 17:04
rjsa wrote:
23 Oct 2017, 16:54
LVDH wrote:
23 Oct 2017, 16:39
I offered it more than once and never understood why you did not answer, but fine now we are getting somewhere.
First just send me an email explaining how you use AWS and how the environment is setup (how is OF installed and so on). Then let me know what you would expect the AWS button, which we will create for the HPC tab, should do for you.
