McLaren MCL34
DiogoBrand
73
Re: McLaren MCL34
I was thinking about that whole front suspension geometry that lowers the car when steering lock is applied, and that got me thinking:
If when you straighten the wheel you are actually lifting the front of the car, does that mean you have to apply more force than normal to unwind the wheel? Since the caster angle is what creates the self aligning forces for the front wheels, does this geometry means they may have to take extra care with the caster angle so that the self aligning forces are enough to lift the car?
Ground Effect
Ground Effect
Re: McLaren MCL34
mclaren111 wrote:
22 Jun 2019, 09:40
And to think a lot of people thought PP has lost his mojo...
I get the feeling PP was being frustrated by Goss
M840TR
M840TR
313
Re: McLaren MCL34
Interesting comment by AMuS on Merc's front-end:
The car certainly has more downforce than the assembled competition. But is that all? Obviously, the car also generates better mechanical grip and keeps the tire temperatures always in the window via a sophisticated rim heater.
For example, one hears that Mercedes drives ahead with less camber than the opponents. You have to be able to afford that. Almost all of the opponents come to the limit of what Pirelli claims to be. To heat up the tires faster. Disadvantage: This reduces the contact surface of the tire with the road.
https://www.auto-motor-und-sport.de/for ... er-sektor/
f1rules
f1rules
579
Re: McLaren MCL34
more pics added to this great mcl34 galery from france
https://www.f1analisitecnica.com/2019/0 ... llery.html
martinbeiker
martinbeiker
Re: McLaren MCL34
POU still on the cars?
digitalrurouni
digitalrurouni
Re: McLaren MCL34
So happy for McLaren. Also seems like they seem to have figured out the trick with the tires as well?
Re: McLaren MCL34
The Discussion about the new WInd Tunnel has been moved to the TEam Thread.
Re: McLaren MCL34
Not sure if anyone has posted this ...Craig Scarborough is always a good read.
So is the POU change of ride height being caused by when the steering is turned either right or left, the upright moves away from the top of the pushrod. Since it's a rod and is attached, the result is the car drops? If one doesn't have the upright there. It is a smaller change in distance. Kind of like moving at wrist as opposed to moving at the elbow. The further away the join is from the hand the more exaggerated the movement.
https://www.racefans.net/2019/06/22/ana ... uspension/
drunkf1fan
drunkf1fan
Re: McLaren MCL34
DiogoBrand wrote:
22 Jun 2019, 11:14
https://www.skysports.com/f1/news/24100 ... n-part-two
Allison mentions it and talks a fair bit about the wing dropping on turn but basically yes. If you just add that style of suspension to a car without tweaking and working on it then both the car naturally wants to turn to one side rather than stay straight so a driver has to essentially work harder to hold the car straight and bumps/movement down the straight becomes more of a problem to fight to stop the car wanting to turn, but as you say the driver has to work a bit harder to pull the car up as it straightens up.
He basically says there is a reason that Ferrari introduced it and kept taking it on and off car for several months because you really need to have it working smoothly with lots of other fancy adjustments to make the car feel more normal after adding such a system.
f1rules
f1rules
579
Re: McLaren MCL34
No, has been removed
martinbeiker wrote:
22 Jun 2019, 15:49
McMika98
McMika98
-24
Re: McLaren MCL34
Ground Effect wrote:
22 Jun 2019, 12:05
mclaren111 wrote:
22 Jun 2019, 09:40
A certain someone named James Key i believe has been instrumental in this turn of fortunes more so than PP. The car aerodynamically does not stand out at all, front limited, not enough downforce compared to top and even Haas to help in fast corners. Where they have excelled is the tyre operating window and not overheating the rears which most team bar Merc have struggled with. Hallmark of James has been designing cars with stable balance that the drivers can push.
f1rules
f1rules
579
Re: McLaren MCL34
Im sorry but no, james keys influence will only be seen later, this car and its characteristics was in place long before him
Re: McLaren MCL34
McMika98 wrote:
23 Jun 2019, 08:10
22 Jun 2019, 12:05
mclaren111 wrote:
22 Jun 2019, 09:40
James had no hand in MCL34... He only arrived a couple of months ago... As Mclaren said, MCL34 was about getting back to basics and have a solid foundation that can be developed... That has worked well so far... I do agree with being front limited but it seems improvements are being made all the time...
2018 vs 2019
1.32.976 vs 1.29.418 = 3.558 improvement
michl420
michl420
Re: McLaren MCL34
I have thought it all year and it is now confirmed. This car likes hot temperatures and circumstance with high tire degradation. Also noteworthy no cooling outlets by the halo, maybe they not like them (aerodynamic) or too big coolers (improvement possible).
Re: McLaren MCL34
Is that an air "conditioner" at the underside of the wishbone (just to the right of bodywork) or something hanging loose ??
