Don’t think so, no. There would be 2 sections when sliced through some planes.aleks_ader wrote: ↑Thu Feb 03, 2022 10:50 pmIs Mclaren 201X-ish snow plow possible? Or is same as for cape and is virtually impossible?
Those are extremes? So anything between those two designs is legal?jjn9128 wrote: ↑Thu Feb 03, 2022 8:43 pmWho was it asking about this sort of 'moustache' front wing? This is as high as you can get the nose tip and wing within their respective volumes.
https://db3pap006files.storage.live.com ... pmode=none
Yea, I think that's part of the reason we saw more than a few teams raise their eyebrows when Merc demonstrated some extreme squat towards the end of the 2021 season.BassVirolla wrote: ↑Thu Feb 03, 2022 9:35 pmThe suspensions are this year highly restricted, but I think that with a clever conjuction of levers and non linear springs, you can achieve a big and sudden squat of the suspension.
dans79 wrote: ↑Thu Feb 03, 2022 11:59 pmYea, I think that's part of the reason we saw more than a few teams raise their eyebrows when Merc demonstrated some extreme squat towards the end of the 2021 season.BassVirolla wrote: ↑Thu Feb 03, 2022 9:35 pmThe suspensions are this year highly restricted, but I think that with a clever conjuction of levers and non linear springs, you can achieve a big and sudden squat of the suspension.
If you raise up the centre section and feed the floor more you'll need to recover front downforce on the mid or outboard section of the wing. The mid section can be tricky since you have limited suspension AOA and you still need to downwash that air to avoid stalling the top of the floor inlet.godlameroso wrote: ↑Thu Feb 03, 2022 11:37 pmHow would that affect the rest of the front wing?Stu wrote: ↑Thu Feb 03, 2022 8:59 pmThat looks as though it would work nicely with the floorjjn9128 wrote: ↑Thu Feb 03, 2022 8:43 pmWho was it asking about this sort of 'moustache' front wing? This is as high as you can get the nose tip and wing within their respective volumes.
I thought torsion bars were banned in 2022?BassVirolla wrote: ↑Fri Feb 04, 2022 12:18 amhttps://img.directindustry.com/pdf/repo ... 29_1mg.jpgdans79 wrote: ↑Thu Feb 03, 2022 11:59 pmYea, I think that's part of the reason we saw more than a few teams raise their eyebrows when Merc demonstrated some extreme squat towards the end of the 2021 season.BassVirolla wrote: ↑Thu Feb 03, 2022 9:35 pmThe suspensions are this year highly restricted, but I think that with a clever conjuction of levers and non linear springs, you can achieve a big and sudden squat of the suspension.
A commercially available example of a linear to rotary movement mechanism.
Such conversion is not linear at the last part of the straight line movement (when the intermediate lever starts to rotate) to the point that the last millimeters don't induce rotation in the axle at all, and only makes reversing the rotary to linear conversion impossible.
Quite feasible, and practical to make a push / pull rod not twisting the torsion bar during all the suspension travel.
It is going to be interesting to see where the most effective compromise is, hopefully there are a wide variety (I’m hoping for 10!!) of options that are all similarly effective!!!theVortexCreatorY250 wrote: ↑Fri Feb 04, 2022 12:49 amIf you raise up the centre section and feed the floor more you'll need to recover front downforce on the mid or outboard section of the wing. The mid section can be tricky since you have limited suspension AOA and you still need to downwash that air to avoid stalling the top of the floor inlet.
Zynerji wrote: ↑Fri Feb 04, 2022 1:50 amI thought torsion bars were banned in 2022?BassVirolla wrote: ↑Fri Feb 04, 2022 12:18 amhttps://img.directindustry.com/pdf/repo ... 29_1mg.jpg
Quite feasible, and practical to make a push / pull rod not twisting the torsion bar during all the suspension travel.![]()
I like that youtube "Tom Talks" solution: make the centre of the wing generate maximum DF by making the nose as short as possible and pulling the center section of the wing as low and forward as possible, so you can drop the mid section of the wing a bit and produce less upwash, to the benefit of the floor intakes.theVortexCreatorY250 wrote: ↑Fri Feb 04, 2022 12:49 amIf you raise up the centre section and feed the floor more you'll need to recover front downforce on the mid or outboard section of the wing. The mid section can be tricky since you have limited suspension AOA and you still need to downwash that air to avoid stalling the top of the floor inlet.
In terms oh height yeahgodlameroso wrote: ↑Thu Feb 03, 2022 11:51 pmThose are extremes? So anything between those two designs is legal?jjn9128 wrote: ↑Thu Feb 03, 2022 8:43 pmWho was it asking about this sort of 'moustache' front wing? This is as high as you can get the nose tip and wing within their respective volumes.
I tend to agree. It also allows you to have a more agressive underside of the chassis near the front suspension. This can be done since the elements in 'free space' can create a slot gap to the nose and energise the boundary layer beneath the nose - meaning you can make it more aggressive and make more downforce from it. This would be mainly useful for the high downforce tracksBlackout wrote: ↑Fri Feb 04, 2022 8:33 amI like that youtube "Tom Talks" solution: make the centre of the wing generate maximum DF by making the nose as short as possible and pulling the center section of the wing as low and forward as possible, so you can drop the mid section of the wing a bit and produce less upwash, to the benefit of the floor intakes.theVortexCreatorY250 wrote: ↑Fri Feb 04, 2022 12:49 amIf you raise up the centre section and feed the floor more you'll need to recover front downforce on the mid or outboard section of the wing. The mid section can be tricky since you have limited suspension AOA and you still need to downwash that air to avoid stalling the top of the floor inlet.
So like Jin's top right and bottom right variants
https://pbs.twimg.com/media/FJEwPLJXIAo ... =4096x4096
Is a front mini-beam wing allowed under the tip of the nose?jjn9128 wrote: ↑Thu Feb 03, 2022 8:43 pmWho was it asking about this sort of 'moustache' front wing? This is as high as you can get the nose tip and wing within their respective volumes.
This is what I was thinking, basically pushing the limits of the volumes! It also doesn't look to bad in my opinion.jjn9128 wrote: ↑Thu Feb 03, 2022 8:43 pmWho was it asking about this sort of 'moustache' front wing? This is as high as you can get the nose tip and wing within their respective volumes.
