Check your PM.
When using a remote avatar, make sure your host works
That's why I recommend uploading to F1T.
Check your PM.
You mean it used to work?
It might not have
That’s odd, because I have never been able to vote on my iPhone using Safari
It works... if you hit the vote button, hit the button in the dialog box, go into portrait mode, scroll to wherever the dialog box has ended up, hit the vote button (which won't work) close the dialog box, hit the vote button again to reopen the dialog box, then hit the vote button again and voilà! It's just that easy!
Thanks. I'll put it in the manualAJI wrote: ↑Tue Feb 11, 2020 9:55 pmIt works... if you hit the vote button, hit the button in the dialog box, go into portrait mode, scroll to wherever the dialog box has ended up, hit the vote button (which won't work) close the dialog box, hit the vote button again to reopen the dialog box, then hit the vote button again and voilà! It's just that easy!
Who do I sent the tech support invoice to?Steven wrote: ↑Wed Feb 12, 2020 12:12 amThanks. I'll put it in the manualAJI wrote: ↑Tue Feb 11, 2020 9:55 pmIt works... if you hit the vote button, hit the button in the dialog box, go into portrait mode, scroll to wherever the dialog box has ended up, hit the vote button (which won't work) close the dialog box, hit the vote button again to reopen the dialog box, then hit the vote button again and voilà! It's just that easy!![]()
