Interesting how the new car has so much more low speed corner stability, both videos are on pare for most of the lap until the final slow corners section and instantly the 2020 lap looks to be jumping a second ahead of 2019.
Again taking Doug McKiernan’s comments about focussing mainly on the areas that would yield maximum results, they probably felt that redesigning the nose would be a lot of work for a relatively small gain? It might be that moving to a narrow nose throws up a lot of new variables - McLaren seems to have taken two or three seasons to make its narrow concept work. I suspect that when done properly it needs the tub to be redesigned at the front end, and I still have my suspicions that Williams is using a pretty similar tub to last year.humble sabot wrote: ↑Thu Feb 20, 2020 1:26 amThat's probably how they took the internal volume out of the sidepods too.
One thing I'm surprised about is that they aren't one of the teams that went the Merc route on the nose.
Now all of a sudden everybody is convinced narrow noses are obviously better no questions asked, come on...Lotus102 wrote: ↑Thu Feb 20, 2020 8:50 amAgain taking Doug McKiernan’s comments about focussing mainly on the areas that would yield maximum results, they probably felt that redesigning the nose would be a lot of work for a relatively small gain? It might be that moving to a narrow nose throws up a lot of new variables - McLaren seems to have taken two or three seasons to make its narrow concept work. I suspect that when done properly it needs the tub to be redesigned at the front end, and I still have my suspicions that Williams is using a pretty similar tub to last year.humble sabot wrote: ↑Thu Feb 20, 2020 1:26 amThat's probably how they took the internal volume out of the sidepods too.
Does seem that way! And Williams get condemned by the tech experts of e.g. The Race because they still have a wide nose. I'm sure Edd Straw and co will be along to demolish Ferrari's chances any moment now too
Exactly my thoughts, Smedley's comments sounds empty and out of contest if we look all they aspects you have mentioned.Lotus102 wrote: ↑Wed Feb 19, 2020 5:14 pmSmedley had left Williams a year before he made those comments. If you look at my post above you'll see that everything coming from current Williams personnel was cautiously positive. In any case, I'm not sure why we should pay too much attention to counsels of despair, especially as I remember predictions from a certain quarter this time last year that Williams would fold before Abu Dhabi![]()
All that aside, it's pretty obvious from today's running that this year is not going to be worse than last year. The car was built on schedule, it's clearly a big step forward in build quality, and handling seems good from the outset - and more importantly, the technical management is not shambolic. I dare say Williams will still be at the back to start with, but is unquestionably in a better state than last year. The internal rebuilding seems to have paid off.
I was just watching a video about it lol, sorry narrow nose enthusiasts but Gary Anderson is on your side, tough break.Lotus102 wrote: ↑Thu Feb 20, 2020 2:29 pmDoes seem that way! And Williams get condemned by the tech experts of e.g. The Race because they still have a wide nose. I'm sure Edd Straw and co will be along to demolish Ferrari's chances any moment now too![]()
Interesting that they're evaluating different aero bits already. They must have a good baseline from yesterday on the initial package
I don't think this really shows why the car appears to be so bulbous in the upper mid section. Is expansion room necessary there to draw air through the radiators/intercooler?MtthsMlw wrote: ↑Thu Feb 20, 2020 3:10 pmhttps://pbs.twimg.com/media/EROX-zaUEAU ... name=large
via @vialibreenrue93
