not sosaviour stivala wrote: ↑Wed Feb 08, 2023 10:54 amYes. Combustion efficiency will always be the prime target of the ICE part of the power unit. The more so if less fuel use will be allowed.
How do you go talking about religion TommyTommy Cookers wrote: ↑Wed Feb 08, 2023 12:06 pmnot sosaviour stivala wrote: ↑Wed Feb 08, 2023 10:54 amYes. Combustion efficiency will always be the prime target of the ICE part of the power unit. The more so if less fuel use will be allowed.
combustion efficiency is simply the % of the fuel charge that is burned eg c.95% for any engine type
the % of that fuel-burned heat that is converted to work is called thermal efficiency
either indicated TE (in-cylinder measure) or brake TE (crankshaft measure)
in current F1 the ITE is c. 60% and the BTE is c. 50%
It's probably been debated already, but you know.. 110 pages is a bit much to go trough. here's my question.wuzak wrote: ↑Tue Feb 07, 2023 11:06 pmStill can only store 4MJ.Vanja #66 wrote: ↑Tue Feb 07, 2023 5:07 pmAh, thanks, so better recovery is allowed. I like that, gives me even more hope for another good step with 2026 rules.wuzak wrote: ↑Tue Feb 07, 2023 4:00 pmThe Energy Store has a specified minimum weight of 35kg for 2026.
The current ES has a minimum weight of 31kg.
The extra is probably to handle the higher power flows.
The ES has the same restrictions as now - maximum 4MJ difference between maximum and minimum charge, though 9MJ can be recovered and unlimited energy deployed.
It has been implied that one can run the ICE against the MGU-K as you please. This can be done for strategic deployment reasons (harvesting in a section of track without overtaking opportunity in order to defend on straights). This of course would lead to a slower ultimate laptime, but more importantly, the preservation of track position.Juzh wrote: ↑Wed Feb 08, 2023 1:56 pmpasting this from 2026 aero thread as it seems more relevant in this topic
Maybe I'm missing something but is there even a plausible scenario in which a theoretical maximum of 13 MJ can be used up in a lap? Seems completely impossible, and with the removal of the mgu-h component much of the complexity is removed from the equation.
Say you start with 4 MJ stored to start the lap, recovery from braking is additional ~2 MJ at most in best of cases, so unless extra recovery is coming from the already mentioned (and supposedly not allowed as per RBPT engineer) ICE to mgu-k at 100kw what's the purpose of having extra 9 MJ available. Seems like an unreasonable amount.
In fact even starting the lap at 4 MJ stored would be a challenge without this, as regs prohibit charging the battery in garage or pitstop in excess of 100 kj.
5.4.12 The amount of stored energy in any ES may not be increased by more than 100kJ whilst the car is stationary in the pit lane or garage during the Qualifying Session or during a Race pit stop.
Ok, it doesn't specifically say you can't charge in pitlane before qualifying. So you go out at ~8MJ, top up to 10MJ, then you can down to 6MJ after first quali lap. Recover ~1 MJ on inlap, another 2MJ on outlap for second lap, still you're nowhere near allowed recovery, and in fact are dropping total charge with each hotlap...?
Yes, this all makes sense.AR3-GP wrote: ↑Wed Feb 08, 2023 3:39 pmIt has been implied that one can run the ICE against the MGU-K as you please. This can be done for strategic deployment reasons (harvesting in a section of track without overtaking opportunity in order to defend on straights). This of course would lead to a slower ultimate laptime, but more importantly, the preservation of track position.Juzh wrote: ↑Wed Feb 08, 2023 1:56 pmpasting this from 2026 aero thread as it seems more relevant in this topic
Take the ideal scenario. Run up against the MGU-K for most of the lap in Monaco, so you can have full deployment down both of the straights. While Monaco is already impossible to overtake on, it would just take that even further.
One could also imagine running up against the MGU-K during a safetycar or in the pitlane, to have full battery on the outlap or restart lap.
Well without this automated MGU-K harvesting, F1 may become an awful lift and coast affair.Juzh wrote: ↑Wed Feb 08, 2023 3:59 pmYes, this all makes sense.AR3-GP wrote: ↑Wed Feb 08, 2023 3:39 pmIt has been implied that one can run the ICE against the MGU-K as you please. This can be done for strategic deployment reasons (harvesting in a section of track without overtaking opportunity in order to defend on straights). This of course would lead to a slower ultimate laptime, but more importantly, the preservation of track position.Juzh wrote: ↑Wed Feb 08, 2023 1:56 pmpasting this from 2026 aero thread as it seems more relevant in this topic
However given how little energy recovery will be available via braking it's not unfeasible running ICE against mgu-k even on quali laps would be beneficial on certain (most?) tracks at the end of straights.
Problem is, if I understood correctly, we apparently have an RBPT engineer saying this is prohibited, which would be strange given the rule set.
Repeat "Combustion efficiency will always be the prime target of the ICE part of the power unit''. Any differences in ICE power output between competing F1 ICE'S means differences in combustion efficiency levels. The latest developments concentrate in obtaining the fastest combustion time possible with the ability to keep the ICE reliable. The faster the combustion the reduced time available for heat-loss, sends more power to the pistons and less into cooling and exhaust. This is greater combustion efficiency.Tommy Cookers wrote: ↑Wed Feb 08, 2023 12:06 pmnot sosaviour stivala wrote: ↑Wed Feb 08, 2023 10:54 amYes. Combustion efficiency will always be the prime target of the ICE part of the power unit. The more so if less fuel use will be allowed.
the % of the fuel heat that is converted to work is called thermal efficiency
no it isn't greater combustion efficiencysaviour stivala wrote: ↑Wed Feb 08, 2023 4:52 pmRepeat "Combustion efficiency will always be the prime target of the ICE part of the power unit''. ....
Where did I say that? I just said 2 valve guys have a harder time getting the same flow numbers as 4 valve heads(implying 2 valve heads have inherently less flow). You will always get more flow with 4 valves, there's just more area. 2 Valve guys know how the air is supposed to flow in the engine, which also applies to 4 valves. Say what you will, even with CNC machined billet heads, hand finishing is still beneficial.saviour stivala wrote: ↑Wed Feb 08, 2023 4:31 amYear 2026 new Formula one ICE part of the power unit and still dreaming of a two-valve-head, totally confusing to say the least, but claiming that a two valve head can ever match a four valve head flow is balderdash.
about 100 posters here have trotted out M-B's proclamation that NA F1 (ie till 2013) was 28 or 29% efficientsaviour stivala wrote: ↑Wed Feb 08, 2023 7:20 pm''An indicated thermal efficiency of almost 28% is obtainable with gasoline engines having a moderate compression ratio''. Is this quote from Henry Ford time?.
''Where did I say that?'' You said = ''2 valve guys have a harder time getting 'THE SAME FLOW NUMBERS' as 4 valve head''. You were CLEARLY implying that 2 valve heads guys can get the same flow numbers as a 4 VALVE HEADS although having a harder time.godlameroso wrote: ↑Wed Feb 08, 2023 9:41 pmWhere did I say that? I just said 2 valve guys have a harder time getting the same flow numbers as 4 valve heads(implying 2 valve heads have inherently less flow). You will always get more flow with 4 valves, there's just more area. 2 Valve guys know how the air is supposed to flow in the engine, which also applies to 4 valves. Say what you will, even with CNC machined billet heads, hand finishing is still beneficial.saviour stivala wrote: ↑Wed Feb 08, 2023 4:31 amYear 2026 new Formula one ICE part of the power unit and still dreaming of a two-valve-head, totally confusing to say the least, but claiming that a two valve head can ever match a four valve head flow is balderdash.
In any case, sometimes the flow bench lies to you. It won't lie to you as bad with a direct injection engine, but it can still mislead you. More flow numbers don't necessarily translate into more power, although it generally does. It all depends on your testing methods. The plennum and exhaust runners all affect flow and reversion, or lack thereof. Seen it a lot, you have features on the CC that prevent reversion, flow great numbers, and you still end up with detonation or backfires because of poor manifold designs.
