Alpine A522
Alonsismo
Alonsismo
Re: Alpine A522
here we can compare old vs new
Re: Alpine A522
Blackout wrote:
24 Jun 2022, 13:26
The Alpine is also the only car with a low rear cooling outlet. The other cars raise it and shrinkwrap the bodywork around the gearbox (like here on the Toro Rosso for example)
So it seems the other teams wanted to clear that path toward the diffuser top/beam wing bottom as much as possible, whereas Alpine seems to have scarified it a bit (that path is fairly cluttered with all those suspension arms anyway) and cleared the top of the beam wing instead.
https://i.imgur.com/xSk71Wt.jpg
It's visible here too. It's clear how Alpine is using its "unnecessarily" wide and humpy rear bodywork to actively orientate the airflow towards specific areas, and probably to attract some of top flow downwards. #downwash
https://i.imgur.com/rOwJSR4.png
https://www.flickr.com/photos/jonmcclin ... 0299877691
Seems Alpine have moved away from this feature that was different to others on the grid. Perhaps more shrinkwrap around the gearbox is ultimately the way to go - the fact Alpine have followed everyone else almost certainly confirms it is.. at least with the current concepts on display
SmallSoldier
SmallSoldier
477
Re: Alpine A522
Detail of the cooling for the new package:
Via: Albert Fabrega
Re: Alpine A522
The raised outlet with tight bottom probably works nicely with the new RB-style double beam wing...
*The other day, was also going to mention that gearbox pull rod rocker blister (green) which could stand in the way if Alpine decided to tighten the bodywork in that area, so Alpine would need to make some ajustements... :P
Re: Alpine A522
Blackout wrote:
30 Jun 2022, 16:38
https://pbs.twimg.com/media/FWgeGBlUsAI ... name=large
The rear part of the engine cover now looks like the RBR rear with the big tunnel around the exhaust pipe...
Ashwinv16
Re: Alpine A522
SmallSoldier wrote:
30 Jun 2022, 16:38
https://i.imgur.com/UzBxW1A.jpg
Via: Albert Fabrega
Alpine is the only so far to pursue the overbody Coanda Effect aggreseively. If thsi works it could be worth nearly a second in some tracks (as it gives huge downforce boost at mediuim speed corners) (See 2015 Ferrari for proof)
Halo not as bad as we thought
Re: Alpine A522
The floor cuts look different too. Their vertical part, the fence (purple), formed a 90° angle with the floor before, but now there is a rounded transition or a fillet
AMuS - Nextegen-Auto - Fabrega
Re: Alpine A522
They've added an extra undercut to the side of the sidepod, the yellow line I added...
Redragon
19
Re: Alpine A522
Also the spanish press is saying that Alpine is bringing a new chasis for Alonso too
Re: Alpine A522
Blackout wrote:
30 Jun 2022, 18:00
https://pbs.twimg.com/media/FWgx8K9XkAI ... ame=medium
It looks like BEFORE that section was a "hack job" of the original piece of that floor. While this is a new fabrication of the piece with the changes incorporated ?
Re: Alpine A522
diffuser wrote:
30 Jun 2022, 18:39
https://i.ibb.co/dLSh7Pj/alpine-a522-si ... tail-1.jpg
Indeed
Re: Alpine A522
Couple of other picts I found ...
Re: Alpine A522
GB VS AUS (The Race - Fabrega)
Re: Alpine A522
Pic 2 - bringing back the hoover nose
Re: Alpine A522
Found better pictures that show the rear bodywork and floor/diffuser changes
XPB/Nextgen-Auto - Albert Fabrega
