PlatinumZealot wrote: ↑Mon May 16, 2022 4:08 pm
VacuousFlamboyant wrote: ↑Sat May 14, 2022 11:27 pm
The new sidepods left much of the floor at the back of the car unchanged. If anything, the reduced sidepod increased its contact area at the front (no undercut).
Well if it is zero pods you would not see any undercut now would you. The profile in plan view of the barge board area is similar to an undercut side pod though. It is actually not as flat-fronted as the Ferrari so I don't see an issue there.
This could lead to adverse effects, choking the higher velocity lower pressure part of the venturi tunnels when the rear lowers. The rear section of the floor in the early spec flexed too, but the rigit front and exposed rear end could unbalance the flow below the car even more. Mixed signals.
Not true actually. If you had a higher pressure at the entrance of the floor, the venturi can accept more flow. This is what Ferrari has done with that flat fronted side pod. Mercedes is in between Ferrari and the stream-line undercut of Red-Bull/Alfa Romeo. On the far end of the spectrum is Aston Martin.
The entry can accept more, but the rear can't. If the rear edges bend to the point that air has nowhere to go, the floor chokes. Subsequently, the abrupt compression and decompression of the floor create vortexes in opposite directions, similar to wing flutter, due to the interaction between friction drag and pressure in that area.
Ferrari and RB floors bend less because they are sustained by the sidepods, like scaffolding cables from front to back. RB rather concave floor also distributes the load better, like the arches in an arched bridge. (Then we have the ice skates. That could be incorporated without hurdles).
Exposing more floor at the front yeah.. Maybe.. That is essentially shifting the outwash a bit rear wards. It is something I think they will do.
Regardless of the sidepod design they end up with, they need to (try to) equalize the contact area of the sidepod front to back rather than relying on floor sturdiness. I see three possibilities for the sidepods:
- A sidepod that "spills" closer to the edges of the floor at the back, not just at the front. Updated "zeropods".
- A sidepod with a small undercut at the front, like Ferrari's, with the spill section pushed a bit further back.
- A sidepod with a large undercut with a small spill section at the back. A more conventional approach with reduced footprint. Flipped "zeropod".
