McLaren MCL36
F1Krof
94
Re: McLaren MCL36
Thing is, we don't know what works for this set of regulations. Prior years, we had an idea based on resulted and sip through want tended to work and what not? For all we know, HAAS's build a monster of a car even though on our eyes it does not look like it.
Wroom wroom
f1rules
f1rules
577
Re: McLaren MCL36
as i said, bold design,
https://the-race.com...sion-explained/
McLaren’s technical director James Key hopes McLaren’s choices for the front and rear of the MCL36 are the correct ones, but admits few things are certain in the early stages of a major regulation change.
“So it is a pullrod front suspension [and pushrod rear]; we saw that in past years,” he said.
“It will be pretty obvious when we run the cars – and you can’t really copy it very easily! So it’ll be interesting to see who else does that. I see the Aston Martin is the other way around, for example. The whole suspension layout is about aerodynamics.
“At the front, it’s the only thing you’ve got to play with between the entrance of the floor and the front wing, and depending on how you treat the front wing and where the entry to the floor needs its load condition will kind of set out what you think the best front suspension geometry is.
“I think we’re going to see some really interesting ideas across the group of us. For us, it seems like a good solution to try. It certainly has properties which we are happy with.
“[It’s] mechanically challenging, but we spent a lot of time trying to get that right, knowing the pitfalls of previous years when it was used.“I’m fairly confident it is going to work as expected. The rear of the car is the other question. We’ve been pullrod for a long time. Adrian introduced it in 2009 with his Red Bull. That’s not necessarily needed now.
“You’ve got a restricted wheelbase that restricts the length of the gearbox for example, so you’ve got other possibilities there. But it will be interesting to see what trends have developed. We’ve gone this route. If we’re the only car that’s done that we’ve either got it really, really right or…”
https://the-race.com/formula-1/mark-hug ... explained/
Re: McLaren MCL36
F1Krof wrote:
11 Feb 2022, 22:56
Because the regulations are so restrictive I am concerend that convergence will happen too quickly. Despite the three launch cars having widely differing philosophies their working fundamentals are not far off. A change of side pods, floor and bam! Rival copied (not counting the pull rod push rod of course!)
F1doc
F1doc
Re: McLaren MCL36
PlatinumZealot wrote:
11 Feb 2022, 23:02
Easier said than done with re-packaging and potentially limitations from the monocoque.
siskue2005
70
Re: McLaren MCL36
Is it wise to pushrod rear suspension, especially with the beam wing returning ?
gcdugas
Re: McLaren MCL36
Looks generally good. Tunnel performance and "sealing" the sides are going to be the main area of focus this year. That and balancing a more pliable suspension movement (since less impact gets absorbed by the tire sidewall) with the demand of a more strict ride height management in order to get the most out of the ground effect tunnels.
I understand the lack of sidepod undercut because of the height of the tunnel intake. It seems the Driver is about 3" further back, relative to both axles, than the AMR22. Plus the rear wing is further back relative to the rear wheel. This multiplies the "leverage" on the downforce generated plus it is in slightly cleaner air. Clearly they placed priority in a narrow waist but it comes at an expense. The airbox looks huge like last year's Renault. Will this hinder general drag and will it decrease the quality of the air hitting the rear wing. As for hot air exit... I do not mind the slightly large looking outlet section at the rear axle line. Keep in mind, if the exits are too tight, there is a bunch of pressure throughout the air's journey and this results in "spill over" at the intake area and general untidiness of the flow in that area.
Still, that huge airbox.... hmmm....
Innovation over refinement is the prefered path to performance. -- Get rid of the dopey regs in F1
Hoffman900
Hoffman900
168
Re: McLaren MCL36
siskue2005 wrote:
11 Feb 2022, 23:14
I don’t think anyone here is capable of knowing more than the entire Mclaren design team.
F1Krof
94
Re: McLaren MCL36
11 Feb 2022, 23:02
F1Krof wrote:
11 Feb 2022, 22:56
I have to digress, sorry about it but this is exactly what they wanted. Formula 1 Racing, they meant it this time, LITERALLY! There will be ONE FORMULA CAR, stock racing, budget restriction, standardized parts... and all the other political BS. I don't like what they've done to the sport honestly! I hope this --- doesn't work and forget about this nightmare get things on track as Formula 1 was really meant to be.
Wroom wroom
Zynerji
110
Re: McLaren MCL36
F1doc wrote:
11 Feb 2022, 23:07
11 Feb 2022, 23:02
And budget
wowgr8
wowgr8
29
Re: McLaren MCL36
Those MCL sidepod inlets are definitely what the rulemakers had in mind writing the rules, they look so good, thank you McLaren for considering the aesthetics there
Re: McLaren MCL36
Yes top side impact structure is roughly where it used to hang
SmallSoldier
SmallSoldier
473
Re: McLaren MCL36
siskue2005 wrote:
11 Feb 2022, 23:14
It’s a matter of which one gives more performance… The potential additional space in the Tunnels or the clear air going to the beam wing.
If McLaren has chosen it, their calculations show that they gain more with the pushrod
Re: McLaren MCL36
Maybe Mclaren managed to put the pushrod inboard rear suspensions inside the gearbox casing (despite the presence of a turbine nearby), to minimise the blockage towards the beam wing, and didnt simply put them on top of the gbox, like in the old days..
16
Re: McLaren MCL36
SmallSoldier
SmallSoldier
473
Re: McLaren MCL36
Nice comparison image to the Aston Martin:
