McLaren MCL36
F1NAC
143
Re: McLaren MCL36
Emag wrote:
Fri Feb 11, 2022 8:48 pm
ScrewCaptain27 wrote:
Fri Feb 11, 2022 8:46 pm
I would really like a closer look at that rear suspension. It’s definitely pushrod.
Yes, we havent seen this since forever. Actually, have we ever seen this? That looks so weird.
Teams used to run with pushrod set up until RB started in 2009 going pull rod. Last time I remember seeing that at rear was on 150Italia, and few other cars in 2011
NtsParadize
NtsParadize
Re: McLaren MCL36
BlueCheetah66 wrote:
Fri Feb 11, 2022 9:01 pm
Interesting that there is no shots from the rear. Maybe they have found a loophole in that area
KingHamilton01
Re: McLaren MCL36
Guy's just some context for those who are saying it look's basic in some area's:- James Key tells us it's the real car, with a few omissions:
"We have hidden some bits and pieces because there are some sensitive areas for obvious reasons, but everyone will see them anyway when we run the car."
McLaren Mercedes
JPower
JPower
Re: McLaren MCL36
Obviously, the cars are different mechanically and aero wise, but from the overhead, I think James Key has a trademark at this point.
Long nose, slim sidepods, cooling mounted up high. I'm guessing this car will be a low drag speedster like the last one.
SmallSoldier
SmallSoldier
342
Re: McLaren MCL36
SmallSoldier wrote:
Fri Feb 11, 2022 8:58 pm
If this is the brake duct… That’s ridiculously small!
https://i.imgur.com/VL1X9Bp.jpg
It most definitely isn’t.
Thanks… If it was… Damn!
mythr-ran-dire
mythr-ran-dire
Re: 2022 - McLaren Formula 1 Team
So I'm not going crazy! It really is a pushrod at the rear? What could the motivation be?
]=Do=>}
~~ ]=Do=>}
Wheel-to-wheel
Re: McLaren MCL36
That's a lot of floor space.
west52keep64
51
Re: McLaren MCL36
So here's my crazy theory on what they are doing with the venturi tunnels.
It's a bit crude, and they aren't exactly shaped like this but you get the idea. They might be using the full width of the floor rather than just the area the rules try to force them to use. I suspect they'll need to seal the edge of the floor to make this work, which is possibly why we aren't see any images of the strakes or the t-tray area.
timbo
timbo
109
Re: McLaren MCL36
F1NAC wrote:
Fri Feb 11, 2022 9:02 pm
Yes, but that was more or less a conventional double-wishbone setup with pushrod passed within top wishbone span. On MCL36 it is multilink with the pushrod slanted to the front heavily.
Xero
32
Re: McLaren MCL36
Noticed a bunch of small ridges along the front wing before it bends up to the "end-plate". Looks like they are trying to generate vortices to skirt around the front tyre for some wake management.
Edit: appears to be a render issue with the objects not aligned correctly. The rules state there should be no discontinuity in this area, and therefore would be illegal. There's another lower down view that shows it better as being misaligned render meshes.
MrGapes
MrGapes
Re: McLaren MCL36
Quickly hoping on the forum to ask what the hell is going on with the suspension?
Rear suspension*
SmallSoldier
SmallSoldier
342
Re: McLaren MCL36
Xero wrote:
Fri Feb 11, 2022 9:09 pm
https://cullenfc.co.uk/xero/images/McLaren%202022a.jpg
Nice catch!
Re: McLaren MCL36
Oh! loopholes
VG generators to aid air extraction from upcoming louvers :?:
jjn9128
744
Re: McLaren MCL36
I retract my original reaction, it's a lot more interesting than I thought - though obviously hiding a lot.
#aerogandalf
the EDGE
the EDGE
65
Re: McLaren MCL36
Blackout wrote:
Fri Feb 11, 2022 9:10 pm
Oh! loopholes
FG generators to aid air extractions from upcoming louvers :?:
https://i.imgur.com/tIGlQpE.png
rear wing with DRS open
Edit... just seen the wider view of this... and obviously not what I said #-o
