More cowbellQuestioner wrote:What would you add to F1technical?
manchild wrote:Extended WDC list.
In races to come, his greatness that has fallen to 10th after Spa, will fall to 11th, and what is the WDC list without "best driver ever"? So, in the name of all his fans I say "We got to have him in sight!"
i agree.andrew wrote:An ignore button? [...] However in extreme cases I think an ignore function would be of use.
Some have been removed, as they were hardly of any positive use anywayzenithbeach wrote:... i would also suggest removing the following smilies as they seem to incite aggression and defensive argumentation instead of discussion:
:^o [-X
True. What then ends up happening is that another member then ends up quoting even more text in reply.xpensive wrote:Equally, there should be a function limiting members to post the link only, not whole bloody shabang from their favourite blog-rambler. You can often see the latter happening, even from xperienced members, most frustrating that.
