Because the corner is probably a mid speed corner or a chicane. I think a car can easily follow through a corner like 130R, or the long left turn in Sochi. Just like cars can easily follow other cars in most high speed ovals.jjn9128 wrote: ↑21 Mar 2018, 19:00I don't think more downforce is the answer. The slipstream is the same effect as dirty air, it's just beneficial on a straight and detrimental in a corner so has a different name. The problem with relying on the slipstream is that car's can't get close enough in corners to make use of it - even with DRS in some cases.godlameroso wrote: ↑21 Mar 2018, 18:49Promote overtaking by having less mid speed corners, and removing chicanes at the end of straights. Reducing downforce won't affect overtaking, increasing drag will because the slip stream effect will be stronger.
As it is now, the cars can stay with each other because of the high drag, but they can't follow closely because they lose too much aero balance. As teams find more consistent downforce following will become easier, and slipstreaming will be more effective, therefore, I think more downforce is the answer. At worst nothing changes, at best cars will be able to follow closer.
COTA and China had overtaking, why, long straights, no chicanes, more high and low speed corners than mid speed corners.
Spa had very little overtaking, why, sector 2 is only mid speed corners save for Pouhon, all long straights end with chicanes.
Abu Dhabi had almost no overtaking at all, why, every straight ends with a chicane some straights end in a triple chicane, and almost every corner is mid speed.
Spain and Hungary have very little overtaking, why, almost every corner is mid speed.
