Lotus T127 Cosworth
zgred
Re: Lotus T127
volarchico
volarchico
Re: Lotus T127
zgred wrote:Image
Is that the front flap actuator?
Re: Lotus T127
that is one of the two actuators then and ALOT of hardware.. is this the way to reduce weight???
would I have a heavy autosport connector in the endplate ? I don´t think the two assemblies can weigh much less than 500g each... wow..
zgred
Re: Lotus T127
Enlarge with click for the details.
thedutchguy
Re: Lotus T127
zgred wrote:http://motorsport.nextgen-auto.com/gall ... medium.jpg
Interesting. Didn't know tat F1 cars are apparently running only about 18 psi or 1.2 bars of tire pressure.
227
Re: Lotus T127
Yeah, the pressure builds with the temperature and centrifugal forces in the tyre.
Belatti
Belatti
Re: Lotus T127
nt
thedutchguy wrote: Interesting. Didn't know tat F1 cars are apparently running only about 18 psi or 1.2 bars of tire pressure.
Hasnt change much since I heard about those numbers 15 years ago.
raceman
Re: Lotus T127
zgred wrote:Image
WOW!
This is the simplest front wing actuator seen amongst others seen till date (with length to full endplate). Cool!
bar555
bar555
Re: Lotus T127
Perhaps this is not the T127 complete front wing angle adjustment mechanism . I assume that there is an additional mechanism housed inside the wing's flap but i do not have a photo to verify it .
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
imightbewrong
imightbewrong
Re: Lotus T127
Courtesy of nextgen-auto.com:
Re: Lotus T127
I dont get the point about the step around the crashbox and aft the sidepods end. The HRT got same.
Re: Lotus T127
Maybe the double diffuser throat begins from there. It could be a rough rendition.?
raymondu999
Re: Lotus T127
Quite interesting how they opted for a Mercedes-like razor fin rather than a more conventional sharkfin like some of the other teams
失败者找理由,成功者找方法
zgred
Re: Lotus T127
raceman
Re: Lotus T127
Photo of Lotus pit. Why is that marking and what may be the purpose??
