Renault R31
Donuts
Re: Renault R31
James Allison also mentioned that a lot of focus has been on the adjustable rear wing. A hint that they might have "tweaked" something? :shock:
By the way, I've read several teams talking about less downforce this year, but if I remember correctly, Eric Boulllier(I think it was before last season ended) said that the R31 allready had more downforce than the R30. Well, I guess we'll see as the season progresses... [-o<
One more thing! How much KERS experience did Renault F1 have in 2009? Any at all? I remember BMW-Sauber-F1 only had KERS for some tracks. Robert Kubica should'nt need too much time to adjust to it. As for Vitaly Petrov, we'll... maybe he is even better of without it? :wink: I guess reliability can be tested in the factory, so it should'nt be of too much worry, some teams are not even bringing their new cars for the first test. :!:
The speed of Ayrton Senna.
The mind of Alain Prost.
The dedication of Michael Schumacher.
The determination of Alex Zanardi.
raymondu999
Re: Renault R31
I think what he might mean is maybe they made a rear wing design which only loses a little bit of downforce when it's retracted, while losing a lot of drag.
Also, I think the R31 CHASSIS would be a lot faster than the R30 chassis, but we have to deduct the downforce from the DDD. Renault had less experience than BMW if I'm not wrong. They only had it for a few races, then only had it back for Monza
失败者找理由,成功者找方法
Donuts
Re: Renault R31
raymondu999 wrote:I think what he might mean is maybe they made a rear wing design which only loses a little bit of downforce when it's retracted, while losing a lot of drag.
Not sure I understand, retracted as in activated? When it's activated, downforce is not an issue.
It's tricky(ofcourse), beacuse you need good top speed without activating the device, to get close enough to be able to activate the device. From what I understand, the "zone" for activating the device will be at a surten distance from the braking point on a straight.
Donuts
Re: Renault R31
Metal
Metal
Re: Renault R31
Donuts could you give me the source where Boullier said that R31 has more downforce than R30. Cuz i only heard that it is more competetive. Thanks.
When the rear wing is being retracted the downforce doesnt matter raymondu, you do it only on the straights.
Neno
Neno
-29
Re: Renault R31
Metal wrote:Donuts could you give me the source where Boullier said that R31 has more downforce than R30. Cuz i only heard that it is more competetive. Thanks.
I think they said this around Belgian GP .Actually they said that R31 had the same amount of downforce as R30 around August/September (Renault stopped developing R30 after Spa. So if R31 had the same amount of downforce in August as R30 in the end of the season then...) and they were and are still finding more so I won't be suprised if R31 has more downforce than R30. What's more interesting, they said that R31 will produce downforce in totaly different way than R30.
Donuts
Re: Renault R31
It was the Renault F1 Team Podcast, I don't think it's available any more. I can't find it text anywhere... sorry.
Metal
Metal
Re: Renault R31
Ok, np, thanks for the info guys.
korzeniow
korzeniow
Re: Renault R31
Donuts wrote:James Allison also mentioned that a lot of focus has been on the adjustable rear wing. A hint that they might have "tweaked" something? :shock:
Bolded: No he didn't say that. There is no quote nor article stating such thing. It was just some forumer at autosport froum who stated this rumour, which was then quickly spread out by Renault/Kubica supporters over the internet.
February 5, 2013
Boost
Boost
Re: Renault R31
You can actually only use it on one specified straight on each circuit. The wing then moves back into downforce position the moment the brakes are hit for the following corner.
madly
madly
Re: Renault R31
From Twitter:
It's alive! The R31 took its first breath this afternoon as we had a successful fire-up of chassis number 1.
http://yfrog.com/h33zhgj
madly
madly
Re: Renault R31
Timstr
Timstr
Re: Renault R31
So what's up with what looks like an extra air intake left of the main air intake?
JohnsonsEvilTwin
Re: Renault R31
They could be using last years shell
More could have been done.
David Purley
adrianjordan
Re: Renault R31
It looks like a more extreme version of what Williams (I think) had or their 2010 car...
Favourite team: McLaren
