Toro Rosso STR6 Ferrari
forty-two
Re: Toro Rosso STR6 Ferrari
gibells wrote:There's an interesting hole at the top of the side-pod by the guys elbow. Kers Cooling?
I've a sneaking suspicion that the hole you're seeing there contains the GPS device. I know that in the past these have been located in the tub, normally near the driver's shins, but I saw a picture of the forthcoming Lotus and it too apparently had a circular access panel in the same location.
Plus, since the front of the sidepod is all "hole" anyway, why would a hole in the top of the pod be helpful for cooling?
imightbewrong
imightbewrong
Good news - earlier today our 2011 chassis passed all its tests and is fully homologated for racing.
https://twitter.com/#!/ToroRossoSpy/sta ... 9469759488
H. Zedozil
raymondu999
Is that another square sidepod design? I don't get why they didn't base off the rb6 design rather than an str5?
失败者找理由,成功者找方法
Formula None
Formula None
Poor Toro Rosso gets it tail cut off and wide rear? :(
ESPImperium
ESPImperium
64
raymondu999
I think they're only the 2nd team to show an undercut on their sidepods. Aren't they?
失败者找理由,成功者找方法
creedbratton
creedbratton
Can anyone explain the slits in the gurney flap above the diffuser? Kinda defeats the purpose...
ESPImperium
ESPImperium
64
Lorenzo_Bandini
Lorenzo_Bandini
They are some rumors that said that TR using double floor like Ferrari in 1992
volarchico
volarchico
What's the exhaust looking thing coming up out of the floor near the rear tire?
I was dreaming to see a new Ferrar 92A in 2011 and STR did it. Nice job STR
forty-two
volarchico wrote:What's the exhaust looking thing coming up out of the floor near the rear tire?
Probably a silly answer, but could it be the exhaust?
volarchico
volarchico
forty-two wrote:Probably a silly answer, but could it be the exhaust?
Well, that's what it looks like but it doesn't make much sense. A little bit further behind, you can see the path they've created for the exhaust. Seems to be something different. And why would you route an exhaust down and then back up through the floor?
forty-two
Oh yes, well spotted.
Perhaps they're going to try routing the exhaust in two different places. The panel you mentioned appears to be made from a different material from the rest of the floor (or it might be a trick of the light!), so I thought that this was heat-resistant material.
Perhaps the idea is that routing the exhausts down through the floor and then back up again is a sneaky way of using the exhaust as a venturi to "suck" air up from under the floor. I know that the exhaust outlet is only allowed to be in two places, and I imagine it isn't allowed to actually EXIT under the car, but what if it had an exit port resting just above a recess in the floor(out of sight in the above image) and a hole through the floor immediately underneath it. When the exhaust gases are pumping backwards (and upwards a little due to the angle of the recess) maybe this could be used to draw air up through a gap in the floor?
Or would the gap in the floor be illegal? I remember last year there were all sorts of scoops and holes appearing near this region, just in front of the rear tyres.
I know I'm not explaining what I mean very well there, perhaps a little MSPAINT drawing is in order?
