Sauber C30 Ferrari
raymondu999
Re: Sauber C30 Ferrari
n smikle wrote:Anybody notice that the suspension is just like Ferrari's? The push-rods are carried forward by about 10 inches? It has potential for a real clean back end.
Yup James Key also said they made a special pushrod arrangement
失败者找理由,成功者找方法
Giblet
Giblet
Temperature stickers everywhere, plus the asymmetrical crash structure. I suspect each side of the car is a slightly different concept they are playing with to evaluate both at once. If not, it must have more air coming out one side than the other which could be KERS heat coming out.
Pierce89
They use the Ferrari gearbox, so really benefitted in suspension design.
H. Zedozil
Owen.C93 wrote:I think here you can see how the exhaust blows into the starter hole. I like how they've aimed the exhausts at the center of the diffuser and used some gurney flaps to extend it around the crash structure.
Scarbs: Sauber are blowing the exhausts in a Vee close to the cars centreline and partly through the starter hole
http://twitpic.com/3v7iov
raymondu999
sorry, I'm failing to see how one leads to the other
失败者找理由,成功者找方法
mith
Scarbs confirming C30 is blowing diffuser partly through the starter hole.
P.S. Is this forum working really slowly today? Massive load?
ell66
ell66
Yup James Key also said they made a special pushrod arrangement[/quote]
They use the Ferrari gearbox, so really benefitted in suspension design.[/quote]
sorry, I'm failing to see how one leads to the other[/quote]
because ferrari had to change there gear box to accomadate the change is suspension, sauber use the same gearbox so they also do the same.
siskue2005
70
scarbs also confirming that Sauber blowing into a channel other than the starter hole?
http://twitpic.com/3v84d8
robbertmd
robbertmd
Maybe interesting for some to see the rear wing adjuster from the Sauber C30 in action.
luca
luca
Cool pic, thanks! :)
mith
Wow, I didn't know it is being adjusted so fast!
@Siskue: Yes, he did confirm it, as I posted it earlier. Nice drawing though.
King Six
King Six
Cool .gif, where's the source video for that?
Predator
King Six wrote:Cool .gif, where's the source video for that?
http://www.youtube.com/watch?v=YUaAb-W5ITw
Florio
Florio
Loving the car, I hate the livery though. I could do better versions on Paint. The suspension looks further forward then Ferrari's if only slightly?
mith
Thanks for the link. You can see some raindrops around the half of it...
