DRS in Monza/New top speed records?/Best place to sit
siskue2005
70
Re: DRS in Monza/New top speed records?/Best place to sit
volarchico wrote:
siskue2005 wrote:
volarchico wrote:I'll further a rumor I read elsewhere in F1T...in Monza, the DRS will work backwards and will be up for most of the race and down for specific corners. ;)
Thats not possible
as the DRS cuts itself off automatically when a car hits the brake
Hence the winking smile and the mention of "rumor"...
:roll:
raymondu999
siskue2005 wrote:4. after the chicane
which chicane are you talking about?
失败者找理由,成功者找方法
volarchico
volarchico
@siskue: why the eye roll? I think everyone else got the fact that it was a sarcastic post without feeling the need to comment. Does that bother you?
andrew
andrew
Location: Aberdeen, Scotland - WhiteBlue Country (not the region)
siskue2005 wrote:
andrew wrote:At Monaco, they need all the downforce available. I think using it would be extremely dangerous anywhere on the circuit. Maybe the tunnel but I can't think of anywhere that would be safe enough.
I can think of 4 places
1. Start finish straight
2. few meters up to the casino square
3. in the tunnel
Noe of which are particularly safe considering the lack of straight and even track.
Just_a_fan wrote:The only place I can think of is the run up the hill at Beau Rivage as it's close enough to being straight for an F1 car. But it's quite short and there's no overtaking opportunity so of little overall benefit in using DRS.
The tunnel would be "interesting" - consider the shunts in the last couple of years where drivers have been slightly offline etc through the tunnel.
I don't see the DRS realistically being used at at Monaco (although no doubt they'll end up with a silly little run of it on the pit straight in front of the royal box just for show...)
The run would be so short it'll be of no benefit to anyone. I agree that the run up the hill at Bau Rivage is a possibility but the cars are unstable enough as it over the bumps.
Richard
Richard
That would be fun for Monaco. Cars run with DRS at all times, then the car being chased goes to a full flap when there is less than 1 second lead.
siskue2005
70
Nouvelle chicane
StrFerrari4Ever
That's what I thought as well and pulling off a move there with your DRS open would only end up in the barriers in all honesty. The only safe way I can see DRS being used effectively in Monaco is if there's lighting in the tunnel which will never happen since it takes away the challenge of that part of the track.
siskue2005
70
did Mclaren use F-duct at monaco last year?
anyone have any onboard video?
Yup they had it on the car, whether or not the drivers actually used it is the question.
☄️ Myth of the five suns. ☄️
LxVxFxHxN
raymondu999
I think we need to remember that with the loss of the DDD the cars will have a lot less downforce, and the DRS will shed more downforce than the F-duct. MP4-25 with F-duct has much more downforce than MP4-26 with DRS.
失败者找理由,成功者找方法
Richied76
Richied76
I think you've all missed one BIG point when it comes to monza. Tire wear! Look at the short stretch after the hairpin at china. Cars with good tires were out dragging worn tired cars in the short run into the final corner. Traction is just as important out of the slow chicanes at monza and i think running with a lower DF level will ultimatly loose you alot of time in race pace. Pirelli will no doubt bring the soft and super soft and looking after them in the italian summer with no DF will be hard when your mashing the throttle into the floor out of the chicanes. Plus latteral slip destroys tires. Long right hand corners of curva grande and parabolica will put alot of stress on the soft sidewalls of the tire.
Also....Balance. If you go light on DF, on the rear, to get a good aero balance the front wing will also need to be trimmed back, which MAY nullify, any top speed advantage, being able to follow close enough through parabolica to even get a chance of using a less affective than usual DRS to over take...
Your thoughts please...
raymondu999
Eh? I disagree. Monza has always been very kind on tyres.
失败者找理由,成功者找方法
Richied76
Richied76
Kind on Brigestone, sticky, durable tires. Tires that were designed to last and still be quick. Every driver has been saying how its the rears that go first. So its got to be the acceleration thats killing them. If you lower your DF you lower your apex speed needing more acceleration. OR you carry on at the same speed with low DF and ask more mechanicaly from the tires..wearing them further. With such a large part of the DF from the DDD last year i see the need for more wing. I think it will play evidence to who has the better blown floor as they wont need to use as much wing.
also remember 2005 at Indy, the michelin tires construction was to blame for the MASSIVE amount of wear on the rears in the long final corner. Pirelli admited to removing a level of construction the aided in tire life.
Did anyone else see the back straight at china where there was a dark line of rubber all the way down off the racing line? Even if the durability isnt tested, in the DRS zone, there will be loads of marbles.
Richard
Richard
Here's an interesting discussion of the subject by James Allen http://www.jamesallenonf1.com/2011/04/w ... -the-race/
beelsebob
beelsebob
85
Wouldn't that give the advantage to the leading car?
