Williams FW42
cravenciak
cravenciak
Re: Williams FW42
nacho wrote:
Fri Mar 01, 2019 12:26 pm
Twitter reports say car looks nervous, no wonder though with the lack of testing and parts missing.
I think it's all about the missing parts. Both George and Robert did report that during some runs prior to thursday FW42 was surprisingly good.
McG
Re: Williams FW42
madly wrote:
Tue Feb 26, 2019 11:56 am
From AMuS:
https://imgr2.auto-motor-und-sport.de/G ... 431057.jpg
What's going on here?
Honda, The Power Of Giving Up.
Red Bull Gives You Flexiwings.
Maritimer
Maritimer
22
Re: Williams FW42
McG wrote:
Thu Mar 07, 2019 6:30 am
From AMuS:
Deflection testing, cameras watch the checkerboard stickers to calculate flex along the wing.
McG
Re: Williams FW42
Maritimer wrote:
Thu Mar 07, 2019 7:28 am
From AMuS:
Wow didn't know a wing could flex upwards so much.
Re: Williams FW42
McG
Re: Williams FW42
Shouldn't be difficult to modify for Australia. Williams used to do this kind of thing in testing back in the day but haven't noticed it in the past 10 years or so.
cplchanb
cplchanb
Re: Williams FW42
Is this car so bad that its thread doesnt even get to get stickied?? :(
Re: Williams FW42
ScrewCaptain27
575
Re: Williams FW42
He mentions how the top vane that mounts to the chassis is non-structural, that is not true. If you look closely there are two small pins attaching it to the mirror. As far as I know there are visibility issues, they are the main reason it was rejected.
- Serj Tankian
Re: Williams FW42
McG wrote:
Thu Mar 07, 2019 8:39 pm
remember this team couldn't even get their car ready for testing, and meanwhile, the TD is gone.
wouldn't be 'too difficult' for a team like Mercedes. Williams, especially in the bad weather they're in now, is an entirely different story.
also, this isn't the williams from back in the day so that doesn't go anyway.
and don't forget how the entire car works together. the suspension has been designed like they did with a philosophy, so it has far greater impact than you'd think.
Dumpster sounds so much more classy. It's the diamond of the cesspools.
FW17
238
Re: Williams FW42
Manoah2u wrote:
Sun Mar 10, 2019 6:11 am
The wishbone might not work as intended but it is just a matter of taping the lower wishbone and the additional piece together.
The mirror can be modified with last year's
I am not sure what the issue is with the rubber shroud over the top wishbone and upright connection
Moctecus
Re: Williams FW42
FW17 wrote:
Sun Mar 10, 2019 11:14 am
Motorsport.com says Williams will "change to a new version that the team has not run before".
The same Motorsport.com article says the shroud has been cleared by the FIA.
Zynerji
Re: Williams FW42
ScrewCaptain27 wrote:
Sat Mar 09, 2019 11:00 am
I called similar on the RBR. I think they are going to have to change them.
CLKGTR
CLKGTR
92
Re: Williams FW42
Which fuel and lubricants Williams use this year? Petrobras went to McLaren and Williams signed with Polish oil company PKN Orlen, but I'm not sure if they supply them with fuel and lubricants... maybe they use Petronas product as Mercedes.
Racing Point uses Ravenol fuel and lubricants, they state it in their RP19 spec tech document, as well as switch from Motegi Racing wheels to OZ Racing.
In Williams FW42 tech specs document fuel is not mentioned, just that wheels are made by AppTech.
Any clues?
Drica
Re: Williams FW42
CLKGTR wrote:
Mon Mar 11, 2019 12:03 am
Any clues?
If i remember correctly (this was from like a year or two ago), all the merc customers use petronas fuels and lubricants but they are sponsored by other oil companies
