[MVRC] Mantium Virtual Racecar Challenge 2019 (Grand Prix Cars)
CAEdevice
38
Re: [MVRC] Mantium Virtual Racecar Challenge 2019 (Grand Prix Cars)
Post by CAEdevice » Tue Aug 13, 2019 5:49 pm
TalnoRacing wrote:
Tue Aug 13, 2019 4:42 pm
Here is the TalnoRacing TR19 for this season's challenge. I was not able to run any CFD, so this is a best guess gut feel design. But I had a lot of fun modelling a sleek looking beast. :D
Nice, clean, quite similar to mine, but more aggressive. Congratulations!
machin
184
Post by machin » Tue Aug 13, 2019 7:27 pm
https://i284.photobucket.com/albums/ll3 ... xekzlu.jpg
Nice! The first proper car reveal! 👍👍👍
rjsa
69
Post by rjsa » Wed Aug 14, 2019 10:22 am
LVDH wrote:
Tue Aug 13, 2019 10:11 am
Code: Select all
lRef        3.4;
to
Code: Select all
lRef        1.0;
Then you can run the case.
This is for the fast option only, right?
CAEdevice
38
Post by CAEdevice » Wed Aug 14, 2019 10:24 am
Code: Select all
lRef        3.4;
to
Code: Select all
lRef        1.0;
I think it is necessary only for the standard template: the "fast" set up includes the correct value of lRef by default (Windows version).
rjsa
69
Post by rjsa » Wed Aug 14, 2019 12:07 pm
I ‘ve gone through the file and the occurrences of lRef read 1 here. Will check again.
Did rake get axed?
rjsa
69
Post by rjsa » Wed Aug 14, 2019 12:25 pm
Yeah, 3.4. I,ve seen lRef 1 somewhere, must have set a fast by mistake while messing around.
CAEdevice
38
Post by CAEdevice » Wed Aug 14, 2019 3:35 pm
Did rake get axed?
No it didn't. It is called "pitch" in the MFlow GUI (don't forget to hit "apply")
rjsa
69
Post by rjsa » Wed Aug 14, 2019 5:22 pm
Did rake get axed?
Negative angles, right?
CAEdevice
38
Post by CAEdevice » Wed Aug 14, 2019 5:39 pm
Did rake get axed?
yes, range from -1° to 0° (nose down)
LVDH
Post by LVDH » Thu Aug 15, 2019 2:43 pm
Did rake get axed?
MFlow should correct it if you do something illegal while having an MVRC template selected.
I have been working pretty hard on a new MFlow release (not only because of your reported bugs) but still cannot package it up for Windows. So there will simply be no new release for the race. This means you have to deal with two bugs.
Depending on what MVRC template you use, the value for lRef is wrong in the system/forceCoeffs file. After building a simulation and before running it, you have to open the file with a text editor and change the value from 3.4 to 1.0. This issue affects the calculation of the CoP.
The second bug is related to the force values on the single parts, you find in the report. These values are all offset by the porous drag of your HX. Essentially they are simply all wrong. The total forces on the car are calculated correctly, though.
jjn9128
244
Post by jjn9128 » Thu Aug 15, 2019 5:59 pm
CAEdevice wrote:
Sat Aug 10, 2019 6:38 pm
It would be amazing having you as a competitor. Why don't you try with a couple of races?
Go on then
Not going to be able to test it though... think I have all the parts in the right places. How is suspension affected with rake? As it's just rotating about the front axle the floor will be moving further from the ground!?
#aerogandalf
CAEdevice
38
Post by CAEdevice » Thu Aug 15, 2019 6:15 pm
Go on then
https://drive.google.com/file/d/1nGDXkz ... sp=sharing
Congratulations! This car is one step above mine about modeling: it reminds me one car of a past challenge that was almost dominant.
CAEdevice
38
Post by CAEdevice » Thu Aug 15, 2019 6:40 pm
What happens if the engine inlet surface is a bit larger than then the duct and it overlaps it by 1-2 mm?
I have the suspect that I have problems when exporting the STL and the surfaces deos not perfectly join.
LVDH
Post by LVDH » Thu Aug 15, 2019 7:15 pm
Scaling these kind of surfaces up so they intersect surrounding geometry is a very good idea. You have to make sure that the remaining surface meetings the requirements on surface area.
CAEdevice
38
Post by CAEdevice » Thu Aug 15, 2019 7:21 pm
No problem, the remaining surface is much larger then required.
