dialtone wrote: ↑08 Aug 2025, 04:21
This article is quoting corriere, not sure how reliable it has been lately, of course not saying it’s not true.
It's better than twitter.
If they raised tire pressure, and they knew this was plank wear related, what’s the point of checking the chassis and saying that they didn’t find any issue?
It was beyond their understanding. That's why they checked the chassis.
None of this makes any sense to me. The article then proceeds to make the same claim of lower engine mode to avoid plank wear despite that mode having been in use since lap 8 and having gone back to full steam on lap 57, which I think is just then speculating.
They didn't have the same engine mode "since lap 8 and having gone back to full steam on lap 57". I pointed this out along with the full radio transmission on the previous page.
The mode increased after the pitstop on lap 20 which you can see by comparing lap 15 to lap 22:
The mode was reduced again on lap 28 when they perhaps realized the tire pressure adjustment at the first stop wasn't enough to reduce the vertical accelerations they were measuring from the bottoming. You can see that by comparing lap 22 to lap 29:
Why they went back to full power again by lap 57 can be explained by futile attempt to keep Russell behind. Russell passed on lap 61/62. They also could have detected that the car was no longer too low (hence the loss of the slow speed performance). Therefore, they were happy to use normal power again.
