aral
aral
26
This thread is going around in circles , quoting unverified sources and theories. Whereas TDs were issued because of some innuendos, it was confirmed by the FIA that nothing was found amiss with the Ferrari PU. It might suit some to believe that there was some cheating, but there has been NO confirmation of any such event. Now, can we please get back to discussing the actual facts relating to the PU rather than all this "he says...you say" etc
The rumours seems sort of strange because any team with a return line, as I said before, can return fuel back to the tank and the flow meter would "double-read" the fuel, under-delivered or not. And, wouldn't these return lines be totally obvious?? This is why a sugested a second sensor on any-return lines to the tank.
Another thing I must mention, the most advanced ultrasonic meters integrate the fuel flow over the entire pipe diameter, in other words they take a velocity snap-shot of the fluid and it is easy to find out what flow regime is occurring in the fluid. Any special temperature manipulation can also be captured by the sensor. Forcing the sensor to under-report the fuel has to be done by some serious outside interference!
Nonserviam85
Nonserviam85
PlatinumZealot wrote: ↑
18 Dec 2019, 20:24
Yeah they are using quantum technology to change the state of the fuel and manipulate the sensor...
saviour stivala
saviour stivala
What fuel flows through the fuel flow sensor must end-up into the combustion chambers. in short, the fuel system is 'returnless', which means there is no fuel returning to the fuel tank.
dans79
267
18 Dec 2019, 20:24
I posted this like two months ago in this thread. The article is about temperature sensors, but if you read the paper you will see how almost any sensor that needs signal amplification could be manipulated.
https://news.engin.umich.edu/2019/09/re ... -industry/
The research paper referenced. https://arxiv.org/pdf/1904.07110.pdf
197 104 103 7
dans79
267
saviour stivala wrote: ↑
18 Dec 2019, 20:41
It has no return line, but that doesn't mean you might not get back flow.
197 104 103 7
saviour stivala
saviour stivala
It is a 'returnless system' and what fuel passes through the fuel flow sensor must end-up in the combustion chambers.
dans79
267
18 Dec 2019, 21:35
I'm sorry to say that I don't think you understand the concept of back flow then. The sensor is not a check valve, so it is possible that do to pressure pulses, pressure build up, line expansion do to pressure etc, the fuel can flow backwards to an extent.
197 104 103 7
saviour stivala
saviour stivala
The fuel flows through the fuel flow sensor under constant pressure. For there to be backflow there must be opposed pressure which is greater then the flow through sensor pressure.
subcritical71
90
dans79 wrote: ↑
18 Dec 2019, 22:37
18 Dec 2019, 21:35
Its my understanding that the sensor is capable of back flow measurement also... to what extent this is implemented and the accuracy I don't know.
ncx
ncx
19
Tmk, the FFM calculates the flow velocity by measuring U/S pulses time-of-flight between two transducers/receivers at fixed positions, longitudinally to the flow, back and forth. I would think that the accuracy is the same in both directions of flow.
saviour stivala
saviour stivala
The sensor is capable to read flow in both directions which means it does not have one directional flow only, a must be inlet port and a must be outlet port.
dans79
267
ncx wrote: ↑
19 Dec 2019, 04:04
I would hope so, or it would be pretty much useless.
197 104 103 7
siskue2005
70
aral wrote: ↑
18 Dec 2019, 12:58
I am sorry, but when did FIA give a statement like that? Could you please direct me to the source? Thank you
aral wrote: ↑
18 Dec 2019, 12:58
siskue2005 wrote: ↑
19 Dec 2019, 07:09
@Aral, Could you please direct me to the source too? I can not find this anywhere. Thank you .
