and you can leave "turbulent" out of the discussion too, it's immaterial in my opinion.
that should light something up
This got my attention. I’m working on a cool Nitro Hemi deal right now.johnny comelately wrote: ↑17 Apr 2018, 01:21As an indication of the effect of these, we fitted them(2 per cyl vertically) to a nitro hemi engine running normal 60BTDC timing.
at start up the blower belt went from smooth running to snaking showing that it was almost running backwards.
timing can come back to under 10 degrees, talk about pumping losses, what this saves in lost power is amazing.
Absolutely make sure you pull timing back to 5 degrees, otherwise you'll have a hole in your walletMrPotatoHead wrote: ↑17 Apr 2018, 03:54This got my attention. I’m working on a cool Nitro Hemi deal right now.johnny comelately wrote: ↑17 Apr 2018, 01:21As an indication of the effect of these, we fitted them(2 per cyl vertically) to a nitro hemi engine running normal 60BTDC timing.
My project is more on the Engineering side that the tuning side.johnny comelately wrote: ↑17 Apr 2018, 04:17Absolutely make sure you pull timing back to 5 degrees, otherwise you'll have a hole in your walletMrPotatoHead wrote: ↑17 Apr 2018, 03:54This got my attention. I’m working on a cool Nitro Hemi deal right now.johnny comelately wrote: ↑17 Apr 2018, 01:21As an indication of the effect of these, we fitted them(2 per cyl vertically) to a nitro hemi engine running normal 60BTDC timing.
Be ready for the effect, no kidding.
AustraliaMrPotatoHead wrote: ↑17 Apr 2018, 04:21My project is more on the Engineering side that the tuning side.johnny comelately wrote: ↑17 Apr 2018, 04:17Absolutely make sure you pull timing back to 5 degrees, otherwise you'll have a hole in your walletMrPotatoHead wrote: ↑17 Apr 2018, 03:54
Now I’m curious which continent you’re on given the time of day
Hmmmmm JB?johnny comelately wrote: ↑17 Apr 2018, 07:51AustraliaMrPotatoHead wrote: ↑17 Apr 2018, 04:21My project is more on the Engineering side that the tuning side.johnny comelately wrote: ↑17 Apr 2018, 04:17
No, he is north of meMrPotatoHead wrote: ↑17 Apr 2018, 13:21Hmmmmm JB?johnny comelately wrote: ↑17 Apr 2018, 07:51AustraliaMrPotatoHead wrote: ↑17 Apr 2018, 04:21
You'd definitely need an ingress portal, does putting a velocity stack in the barrel outlet help? Trumpet shape and what not, or does a straight barrel work best?johnny comelately wrote: ↑17 Apr 2018, 02:27re the nitro engine, because you are dealing with liquid management the vertical placement (which had to be by engine design) worked well because it retained enough air in the spark chamber to initiate properly, as they drown easily (the usual reason they explode).
it had a multiple hole config of about 2mm diam.
this is important to charge the spark chamber. And because it is a hemi config giving plenty of depth for flame to do its thing.
this brings me to the concept honda pictures that were in here somewhere, it had multiple tiny holes that would be impossible to charge through, thus in the centre it looked like an additional ingress mechanism, but all fiction, wish poster would have put CONCEPT at the start or am I blind
this is the insert type for methanol, all volumes and ratios are important.godlameroso wrote: ↑17 Apr 2018, 15:57You'd definitely need an ingress portal, does putting a velocity stack in the barrel outlet help? Trumpet shape and what not, or does a straight barrel work best?johnny comelately wrote: ↑17 Apr 2018, 02:27re the nitro engine, because you are dealing with liquid management the vertical placement (which had to be by engine design) worked well because it retained enough air in the spark chamber to initiate properly, as they drown easily (the usual reason they explode).
I imagine on a Nitro engine getting the concept just right would be tricky as well, you wouldn't want any orifices where non burned nitro could hide as that could also be an explosion waiting to happen.johnny comelately wrote: ↑17 Apr 2018, 02:27re the nitro engine, because you are dealing with liquid management the vertical placement (which had to be by engine design) worked well because it retained enough air in the spark chamber to initiate properly, as they drown easily (the usual reason they explode).
With ultra lean exhaust temperature is reduced 35% as combustion temperature is similarly reduced. The reduced rate of kinetics the number of high energy reactants and products moles bouncing around creating pressure vs spinning doing nothing for pressure at the higher temperature diffusion combustion of stoichiometry.johnny comelately wrote: ↑16 Apr 2018, 23:55Not forgetting it, but from my view not all that related except it gets a significant benefit from better combustion.NL_Fer wrote: ↑15 Apr 2018, 22:31Aren’t you forgetting the mgu-h? The more (excess) air in the mixture, the more the mgu-h can extract from it. Also the turbo has been designed around a certain amount of air/exhaust gas coming through, i don’t believe this still works at lamba 1.0 of it is designed for higher values.
This comes from:
1. a more complete and quicker combustion for a higher total amount of heat and
2. higher pressure exiting the exhaust valve/port
