f1isgood wrote:
02 May 2025, 23:18
I think it's not as bad as I expected. But yeah we can't keep the tires for S3.
I don't think that was the problem. S3 is not bad on the 2nd run. Within 1 tenth of Antonelli and same as Piastri with used tire. Max set purple S1 on the used tire that was unbeaten.
What does he even mean with this
Why did they go for a good tyre life setup on a track where you can't even overtake
f1isgood
f1isgood
02 May 2025, 23:23
f1isgood wrote:
02 May 2025, 23:18
2 tenths in second sector -- potentially improvable with fresh tires -- maybe even S1 a bit more.
Yeah maybe it's not the tires and there's maybe a bit of hope for tomorrow.
Let's see Quali tomorrow maybe they can fight for pole.
Call a spade, a spade.
Sergej
02 May 2025, 23:25
just the usual copium "we set the car for the race" just to see terrible tyre wear :mrgreen:
Sergej wrote:
02 May 2025, 23:26
02 May 2025, 23:25
That's what I expect too but I enjoy that they will continue to say these things :mrgreen:
Emag
Emag
Max is flying on T1, absolutely mighty through there and no other driver got close (except Kimi on his final lap, but still not as good). Practically he makes that entire S1 gap to the others in T1.
On his second run T11 and T17 were bad, but it's hard to know if it's just down to car or poor tire condition. Straight line speed, although better than in practice, was still down relative to others, so it is indeed going to be a weakness for this weekend and not just a practice sandbagging thing. T5-T6-T7-T8 was equally good, but it's all undone by the end of the straight.
Developer of F1InsightsHub
Juzh
161
Kinda meh result.. Hard to see Max is able to overtake anyone with this boat on the straights. Antonelli will get eaten by both mclarens and max will be stuck. They're giving away too much on straights for a measly 1 tenth gain in S1. It will be difficult to compete in the long run with a constant straight line deficit.
Cs98
Cs98
Absolutely dreadful comms from GP in SQ1.
02 May 2025, 23:25
Could be referring to downforce level. The others are quicker on the straights. Maybe they will pay in the long runs.
Albano highlights our issues on the straight
Juzh wrote:
02 May 2025, 23:31
Max will have a tow. The extra downforce is not just for 1 tenth gain in S1. It's also for protecting the tires.
Sergej
Before going into more detailed analysis, there is a slightly strange macro theme: #Verstappen's #RedBull had a very lean power curve throughout qualifying. He loses about 0.2 on the return straight alone. Reliability concerns in the heat? Even just for the sprint? I don't know, strange, let's see if we understand more as we go along #MiamiGP
I didn't think Max would be able to go faster on a used soft tire. He did. That's normally something only Mclaren can do.
I think there's more than meets the eye here.
euv2
euv2
Emag wrote:
02 May 2025, 23:30
Think Max would have been closer with a fresh set and a single push lap; he was just 0.100 off both Kimi and Piastri before T17. Only Mercs are faster in a straight(2-3kmph), Max had the similar top speed as Piastri, so not too bad. Max was quite good out of the chicane on the kerbs and turn 16.
Should do better in qualy tomorrow at least be much closer to the top.
Vettel165
Quite ok, the car looked better. Its just sprint qualy. Lets see if we can fight in the race. Its good if they put more downforce to protect the rear tyres. They can test that tomorrow and then maybe go with less wing again for sunday.
