saviour stivala wrote: ↑25 Oct 2025, 14:38
First, I stand with what I wrote, ''The MGU-K would only be able to deploy energy when car is accelerating, and it would only be able harvest energy when the car is decelerating''. Which in turn means that when the car is accelerating, the driver is on-throttle. And when the car is decelerating, the driver is off-throttle.
What there will be is energy deployment saving. ''The 2026 rules will include track-dependent energy deployment restrictions under full throttle'', to ensure safety and maintain race balance, specifically, cars will not be allowed to use full electrical power on certain tracks, to prevent dangerously high speeds. The rules will also feature a gradual ramp-down of battery power as speeds increase to manage energy output. There will also be speed dependent tapering, the amount of battery power that can be used will decrease as the car's speed increases.
The rule about ramp down rate:
C5.12.6 The
driver maximum power demand must not be reduced at any greater than the rates defined below:
a. 50kW in any 1s period at Competitions where the FIA determines that the power limited distance exceeds 3500m. These Competitions and the vehicle fundamentals used for the calculation of the power limited distance may be found in the document FIA-F1-DOC-Cxxx.
b. 100kW in any 1s period at all other Competitions.
Furthermore, the total power reduction is limited to a maximum of 600kW and the resulting electrical DC power of the ERS-K must remain above −250kW.
Seems pretty clear that (a) this refers to the driver at full throttle and (b) the MGUK power is reduced below 0, that is, it is harvesting. The maximum harvesting under full throttle is 250kW.
You,
WUZAK are interpreting the rules wrongly. There will be no energy recovery under throttle (car accelerating)
If I am wrong, I am not the only one.
You are the only one that seems to be of the impression that that "there will be no energy recovery under throttle (car accelerating)".
I ask you to support your contention with a specific rule that forbids harvesting under acceleration.
Certainly they are not permitted to recover energy when accelerating with maximum power demand, as the PU must match that demand, subject to battery state of charge and speed, but they do not always accelerate at maximum power demand.
In traction limited acceleration they cannot use maximum power demand, so there will be times where it is possible to harvest energy while still accelerating.
