2026 Hybrid Powerunits
DenBommer
DenBommer
wuzak wrote:
21 Oct 2025, 10:06
DenBommer wrote:
21 Oct 2025, 09:32
wuzak wrote:
20 Oct 2025, 18:29
Harevsting the energy allowed will be difficult and require burning extra fuel to achieve it.
Harvesting more would likely require a larger, and heavier, battery.
I've said it before, I don't think front harvesting will help much, unless the total recovery power is much greater.
And it doesn't help with the deployment if the front MGU also deploys.
You would still run out of energy quickly.
So, is a front generator just not a good idea? especially considering they want the cars to be smaller and lighter?
A front generator certainly wouldn't help the quest for lightness.
But could a front generator make the front brakes smaller and lighter?
I know they’re already lightweight, but maybe you could make other parts in the wheel lighter too?
Look at what YASA just achieved. though that’s still in lab conditions. And for a few seconds
https://www.carscoops.com/2025/10/merce ... r-1000-hp/
FW17
185
https://www.planetf1.com/news/audi-f1-2 ... comparison
Merc - 420 kilowatts (571bhp) - 50.4% eff
Ferrari - Close behind
Honda - Not far behind
Red Bull - ?
Audi - 400 kilowatts (536bhp) - 48% eff
670
DenBommer wrote:
23 Oct 2025, 09:32
... But could a front generator make the front brakes smaller and lighter?
of course the disc motor/generator isn't new (and yes it's really good at being disc-shaped)
but relative to the conventional it has more rotational inertia
ie more braking work (and accelerating work) may be needed not less
some drawbacks will be greater with the (direct drive) approach as suggested above ie low rpm high torque
consider that the MGU-K chosen is 50000 - 60000 rpm not the 1500 wheel rpm
IIRC lumps of stuff in the wheels are F1-illegal
dren
228
FW17 wrote:
23 Oct 2025, 10:27
Red Bull - ?
I expect the current PU manufacturers to all be in the same ballpark with the ICE. It'll come down more to control electronics and the extra harvesting they are able to do.
Honda!
DenBommer
DenBommer
Tommy Cookers wrote:
23 Oct 2025, 12:18
DenBommer wrote:
23 Oct 2025, 09:32
Okay, but maybe I wasn’t clear.
I wouldn’t place an axial-flux generator in the wheel, but in the nose, with driveshafts to the front wheels. Like in formula E.
Am I clearer now?
670
IIRC there was a rule (B.A.R. ? c.2000 ?) that banned any rotational interconnection between the front wheels
so maybe 2 chassis-mounted axial-flux gearhead machines each with its own driveshaft to its own front wheel
each somewhat integral with its own (inboard) friction brake and clearly common only at the ES
the ES and the CEs and their cooling systems will be bigger ... and again ....
these 'lighter' A-F machines will be harder to accelerate ie 'heavier' (they are bigger stores of mechanical energy)
wuzak
wuzak
532
23 Oct 2025, 17:37
Benetton had a front diff and axles in 1999 for torque transfer as well.
saviour stivala
saviour stivala
43
There was a rule (BAR c 2000) that banned any rotational inter connection between the front wheels. The BAR used system, Despite being ordered off the cars at its debut in Germany, it was later deemed legal. The formula 1 rules in 2000 that later banned the interconnection of front wheels were part of broader ban on active suspension systems. In 2004 BAR used a front torque transfer system on the front wheels that linked both front wheels via drive shafts, to balance the braking forces, allowing drivers to brake later into a corner. Benetton in 1999, first ran in 1989, in an attempt to counter the tendency for front wheels to lock under braking when cornering, used a viscous coupling/ a fluid differential linking the front wheels via drive shafts, it was stuck on the bulkhead and intruded in the crash area. They worked with GKN and XTRAC to design and build a unit that would give the right slip characteristics.
wuzak
wuzak
532
saviour stivala wrote:
22 Oct 2025, 23:04
The posts by wuzak and diffuser, contrary to what you claim does not convince me otherwise, because I believe solidly that the 2026 MGU-K would only be able to deploy energy when car is accelerating, and it would only be able to harvest energy when the car is decelerating.
Why do you think that?
Is there something in the rules that point in that direction?
There are rules for recovery when under full throttle and at part throttle.
Nothing I've seen says the MGUK can only be used when slowing the car down.
saviour stivala
saviour stivala
43
wuzak wrote:
25 Oct 2025, 12:45
22 Oct 2025, 23:04
First, I stand with what I wrote, ''The MGU-K would only be able to deploy energy when car is accelerating, and it would only be able harvest energy when the car is decelerating''. Which in turn means that when the car is accelerating, the driver is on-throttle. And when the car is decelerating, the driver is off-throttle. You, WUZAK are interpreting the rules wrongly. There will be no energy recovery under throttle (car accelerating), What there will be is energy deployment saving. ''The 2026 rules will include track-dependent energy deployment restrictions under full throttle'', to ensure safety and maintain race balance, specifically, cars will not be allowed to use full electrical power on certain tracks, to prevent dangerously high speeds. The rules will also feature a gradual ramp-down of battery power as speeds increase to manage energy output. There will also be speed dependent tapering, the amount of battery power that can be used will decrease as the car's speed increases.
wuzak
wuzak
532
25 Oct 2025, 14:38
25 Oct 2025, 14:38
The rule about ramp down rate:
C5.12.6 The driver maximum power demand must not be reduced at any greater than the rates defined below:
a. 50kW in any 1s period at Competitions where the FIA determines that the power limited distance exceeds 3500m. These Competitions and the vehicle fundamentals used for the calculation of the power limited distance may be found in the document FIA-F1-DOC-Cxxx.
b. 100kW in any 1s period at all other Competitions.
Furthermore, the total power reduction is limited to a maximum of 600kW and the resulting electrical DC power of the ERS-K must remain above −250kW.
Seems pretty clear that (a) this refers to the driver at full throttle and (b) the MGUK power is reduced below 0, that is, it is harvesting. The maximum harvesting under full throttle is 250kW.
25 Oct 2025, 14:38
If I am wrong, I am not the only one.
You are the only one that seems to be of the impression that that "there will be no energy recovery under throttle (car accelerating)".
I ask you to support your contention with a specific rule that forbids harvesting under acceleration.
Certainly they are not permitted to recover energy when accelerating with maximum power demand, as the PU must match that demand, subject to battery state of charge and speed, but they do not always accelerate at maximum power demand.
In traction limited acceleration they cannot use maximum power demand, so there will be times where it is possible to harvest energy while still accelerating.
saviour stivala
saviour stivala
43
wuzak wrote:
26 Oct 2025, 02:54
25 Oct 2025, 14:38
25 Oct 2025, 14:38
25 Oct 2025, 14:38
The 2026 formula 1 regulations don't allow for energy recovery at full throttle or during acceleration, but instead allows for it under braking (deceleration). In my personal opinion, even if I might be the only one on here saying so, You are misunderstanding and so misinterpreting the 2026 energy harvesting regulations, and in the process, a normal one, (expressing yourself on a discussion forum) it is easier to please others that might be in doubt, because you will be writing what they would like to read.
mzso
mzso
75
23 Oct 2025, 17:37
If one reg change is required (for front regen) why wouldn't they change two?
I don't get why this comes up all the time. If the intention was to allow something, they would adjust all relevant rules.
saviour stivala
saviour stivala
43
With the removal of the MGU-H in 2026, the energy recovery system will no longer recover energy from the turbocharger's heat. This will put exclusive reliance on breaking as the only source of energy recovery, recovery will be from kinetic energy captured by MGU-K during braking.
670
29 Oct 2025, 04:38
... the energy recovery system will no longer recover energy from the turbocharger's heat....
... braking as the only source of energy recovery ....
it can recover some from the KE of the 120000 rpm turbocharger ....
being connected by induction gas and exhaust gas to the ICE/MGU-K combo called the PU
and the 2026 system will recover more energy that's hidden in the KE of the ICE & MGU-K rotation
because the MGU-K is much bigger and faster? rotating typically 50000 rpm
often times per lap the rpm falls eg to 50% so 75% of that KE is recovered and stored in the ES
and many times per lap the rpm falls after it has just been raised by spending fuel
as part of up-shifting and even as part of down-shifting
